[GRASS-user] Using db.out.ogr to export attributes to a csv file
Moritz Lennert
mlennert at club.worldonline.be
Wed Apr 3 02:17:16 PDT 2013
On 02/04/13 22:58, דור פרידמן wrote:
> I have also tried Moritz suggestion with v.db.select. It was much
> convenient with only 1428 entries, though they were formed in one cell
> separated with |.
The | is the cell separator by default. So, it is not one "cell", but as
many "cells" as there are columns in your attribute table. Just indicate
| as the separator to the software you use to treat the data afterwards.
> Can I use that command to define for each column to be
> in a separated column of the csv?
Use the fs= parameter to define a different column separator than |.
Moritz
