[GRASS-user] grass default db driver
Vincent Bain
bain at toraval.fr
Thu Apr 4 03:00:15 PDT 2013
> In G7 it's
> $GISDBASE/$LOCATION_NAME/$MAPSET/sqlite/sqlite.db
> Martin
Thank you for the advice Martin, I had not noticed the sub-dir
difference. Do you mean it is a source of problem ? what happens for
locations created with grass64 and operated with grass70 ? is the
default sqlite.db file moved/copied to the right place ? or is it only a
matter of "dbname" argument provided at db.connect (then no matter where
it lies) ?
Vincent
