[GRASS-user] Error in compilation of GRASS 7 in Ubuntu 12.10
Markus Neteler
neteler at osgeo.org
Thu Apr 4 09:00:47 PDT 2013
On Thu, Apr 4, 2013 at 5:56 PM, Carla Rebelo <crrebelo at gmail.com> wrote:
> In the step of configure GDAL-GRASS plugin for point to GRASS
> installation/binaries
> (http://grasswiki.osgeo.org/wiki/Compile_and_Install_Ubuntu#GRASS_GIS)
> appeared this error:
> "configure: error:
> --with-grass=/usr/local/src/grass_trunk/dist.x86_64-unknown-linux-gnu/
^^^^^^^^^^^^^... trunk!
> requested, but libraries not found! Perhaps you need to set LD_LIBRARY_PATH
> to include /usr/local/src/grass_trunk/dist.x86_64-unknown-linux-gnu//lib?"
To my knowledge, the GDAL-GRASS plugin is still for GRASS 6 only...
Maybe you need to express your interest to get GDAL ticket #2953
http://trac.osgeo.org/gdal/ticket/2953
closed... Or try the patch attached to it (likely it needs an update and to be
updated in the ticket).
Markus
