[GRASS-user] Confusing warning message in GRASS 7 when using g.remove
Rainer M. Krug
Rainer at krugs.de
Mon Apr 8 07:35:59 PDT 2013
Hi
I am using GRASS 7 and I get the following confusing warning message
Removing raster <ACyclops_ageClass_2006 at asmDrak>
WARNING: 'cell/ACyclops_ageClass_2006' was found in more mapsets (also
found in <asmDrak.2006>)
WARNING: Using <ACyclops_ageClass_2006 at asmDrak>
when I want to remove a raster map which is in the mapset asmDrak as
well as asmDrak.2006.
I am in mapset asmDrak and issue
g.remove rast=ACyclops_ageClass_2006 at asmDrak
The warning would be fine if I would not have specified the mapset with
@asmDrak but as I have specified it, I would have expected no warning,
as with the layer name ACyclops_ageClass_2006 at asmDrak I have obviously
refered to the one in asmDrak?
Am I missing something here, or is the warning missleading / wrong?
Cheers,
Rainer
Rainer M. Krug, PhD (Conservation Ecology, SUN), MSc (Conservation Biology, UCT), Dipl. Phys. (Germany)
Centre of Excellence for Invasion Biology
Stellenbosch University
South Africa
Tel : +33 - (0)9 53 10 27 44
Cell: +33 - (0)6 85 62 59 98
Fax : +33 - (0)9 58 10 27 44
Fax (D): +49 - (0)3 21 21 25 22 44
email: Rainer at krugs.de
Skype: RMkrug
Name: not available
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20130408/f0aa7b13/attachment-0001.pgp>
