[GRASS-user] How to force remove broken vector layers?
Allar Haav allar.haav at gmail.com
Wed Apr 10 05:05:43 PDT 2013
As for the latest compiled WinGRASS7, which at the moment (from osgeo4w)
is r55677-547, then this gives the error right at the startup of grass7
(i.e. after g.gui command):
GRASS 7.0.svn> Traceback (most recent call last):
   File "C:\OSGeo4W\apps\grass\grass-7.0.svn\etc\gui\wxpython\wxgui.py",
line 34, in <module>
     from lmgr.frame import GMFrame
   File
"C:\OSGeo4W\apps\grass\grass-7.0.svn\etc\gui\wxpython\lmgr\frame.py",
line 69, in <module>
     from lmgr.pyshell          import PyShellWindow
   File
"C:\OSGeo4W\apps\grass\grass-7.0.svn\etc\gui\wxpython\lmgr\pyshell.py",
line 27, in <module>
     import grass.pygrass as pygrass
   File
"C:\OSGeo4W\apps\grass\grass-7.0.svn\etc\python\grass\pygrass\__init__.py",
line 17, in <module>
     import modules
   File
"C:\OSGeo4W\apps\grass\grass-7.0.svn\etc\python\grass\pygrass\modules\__init__.py",
line 11, in <module>
     import grid
   File
"C:\OSGeo4W\apps\grass\grass-7.0.svn\etc\python\grass\pygrass\modules\grid\__init__.py",
line 9, in <module>
     import grid
   File
"C:\OSGeo4W\apps\grass\grass-7.0.svn\etc\python\grass\pygrass\modules\grid\grid.py",
line 20, in <module>
     _GREG = Module('g.region')
   File
"C:\OSGeo4W\apps\grass\grass-7.0.svn\etc\python\grass\pygrass\modules\interface\module.py",
line 87, in __init__
     raise GrassError(str_err % self.name)
grass.pygrass.errors.GrassError: "Module 'g.region' not found, please
check that the module exist"
Therefore I've been using an older build (r55595-540) with which I have
this curious vector layer deletion issue (which I'm sure I didn't have a
few weeks ago at least). It doesn't matter whether I try to do it in a
script or not, g.remove does not remove vector layers completely. It
seems to get stuck with hist file. There is a chance though that the
issue isn't apparent in a newer build.
One probable solution would be moving on to Unix though.
Allar
On 10/04/2013 12:22, Pietro wrote:
> Hi Allar,
> On Tue, Apr 9, 2013 at 4:20 PM, Allar Haav <allar.haav at gmail.com> wrote:
>> The GRASS 7 I'm running currently however is a week-old r55595-540 as the
>> later ones have been giving the error regarding pygrass and g.region at
>> startup. Could this be the key to my issue?
> Can you provide the code that you are using?
> As I said in grass-dev[0], at the moment the shortcuts are not working properly.
> Pietro
> [0] http://lists.osgeo.org/pipermail/grass-dev/2013-April/062894.html
