[GRASS-user] How to force remove broken vector layers?
Allar Haav allar.haav at gmail.com
Wed Apr 10 05:53:42 PDT 2013
Thank you! Probably this and the change in r55681 resolve my issues.
Allar
On 10/04/2013 13:45, Markus Metz wrote:
> IMHO it is a very bad idea to load pygrass together with the gui, as
> bad as loading nviz or anything else that uses ctypes when the gui is
> loaded. Anything that uses ctypes should be started upon user request
> as a separate process. I am going to revert r55395 (tested on
> Windows).
> Markus M
