[GRASS-user] confused by the GRASS Programmer's topology examples...
G. Allegri
giohappy at gmail.com
Thu Apr 11 03:12:15 PDT 2013
Going on grasping the data structures...
> - Point example: a point doesn't have nodes but have a line (P_LINE),
> with type GV_POINT.
> It's enough for me to get confused :)
> A P_LINE structure has a void * topo opaque element [2], which will point
> to the relative topology structure depending on the type. In case of a
> G_POINT type, what is the topology structure attached to the topo pointer?
Ok, as I supposed the topo pointer is NULL for points.
> - Line example: two nodes with type GV_LINE. A P_NODE doesn't have a type
> [3], so how can it be... a GV_LINE? :(
Sorry, this is clear now. The type is referring to the lines attached to
the node.
> I'm missing something. Could you help to understand it?
> Thanks a lot,
> giovanni
> [1] http://grass.osgeo.org/programming7/vlibTopology.html#vlibTopoExamples
> [2] http://grass.osgeo.org/programming7/structP__line.html
> [3] http://grass.osgeo.org/programming7/structP__node.html
> Giovanni Allegri
> http://about.me/giovanniallegri
> blog: http://blog.spaziogis.it
> GEO+ geomatica in Italia http://bit.ly/GEOplus
Giovanni Allegri
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20130411/18fe533b/attachment.html>
