[GRASS-user] confused by the GRASS Programmer's topology examples...
G. Allegri giohappy at gmail.com
Fri Apr 12 02:38:33 PDT 2013
Thanks very much for the clear explanation.
As I wrote in my self-reply, and as you have highlitghted, I was mixing
some concepts.
I'm studying this because I will probably need to develop some routines for
network analysis. I'm studying the graph structure right now...
Thanks again,
Giovanni
2013/4/12 Markus Metz <markus.metz.giswork at gmail.com>
> On Thu, Apr 11, 2013 at 11:32 AM, G. Allegri <giohappy at gmail.com> wrote:
> > Hi all,
> > I'm reading the GRASS7 programmer's manual, to update my experience with
> > GRASS (I'm going to use it for some network analysis, and probably I will
> > need to extend it)
> You would need to read the  programmer's manual only if you want to
> develop GRASS. The user manual should explain everything needed to use
> GRASS.
> > Looking at the topology examples [1] I fill a bit confused by the
> "types" of
> > nodes and lines, which vary between the different kind of topological
> > structures.
> >  - Point example: a point doesn't have nodes but have a line (P_LINE),
> with
> > type GV_POINT.
> > It's enough for me to get confused :)
> A point (GV_POINT) is not attached to nodes (in GRASS 7). P_line is an
> internal structure that holds information about points, lines,
> boundaries, centroids, faces. Or in your words, a structure P_line
> does not hold information about nodes if it is of type GV_POINT.
> > A P_LINE structure has a void * topo opaque element [2], which will
> point to
> > the relative topology structure depending on the type. In case of a
> G_POINT
> > type, what is the topology structure attached to the topo pointer?
> >  - Line example: two nodes with type GV_LINE. A P_NODE doesn't have a
> type
> > [3], so how can it be... a GV_LINE? :(
> It seems you are mixing internal structures (P_line, P_node) and
> feature types (GV_POINT, GV_LINE, GV_BOUNDARY, GV_CENTROID, GV_FACE).
> In the example, there is one line (GV_LINE), and the end points of the
> line are attached to nodes. Two end points -> two nodes, if the end
> points are different. The "type = 2 (GV_LINE)" in the example for the
> node refers to the feature type attached to the node.
> Markus M
> > I'm missing something. Could you help to understand it?
> > Thanks a lot,
> > giovanni
> > [1]
> http://grass.osgeo.org/programming7/vlibTopology.html#vlibTopoExamples
> > [2] http://grass.osgeo.org/programming7/structP__line.html
> > [3] http://grass.osgeo.org/programming7/structP__node.html
> > Giovanni Allegri
> > http://about.me/giovanniallegri
> > blog: http://blog.spaziogis.it
> > GEO+ geomatica in Italia http://bit.ly/GEOplus
> > grass-user mailing list
> > grass-user at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/grass-user
Giovanni Allegri
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20130412/358cca6a/attachment.html>
