[GRASS-user] Number of centroids outside area: difficulty with	cleaning
    Markus Metz
    markus.metz.giswork at gmail.com
    Sun Apr 14 04:06:02 PDT 2013
On Sun, Apr 14, 2013 at 11:02 AM, RichardC <richtcooper at hotmail.com> wrote:
> Hi,
> I'm trying to remove a 'Number of centroids outside area' after
> re-projecting a file.
> I've tried v.clean with various tools. including breaklines/boundaries,
> break polygons, snap lines/boundaries.
> The intial imported shapefile did not display any errors, but the following
> errors appeared on re-projecting the latter file:
> Building topology for vector map <as_bas_shp>...
> Registering primitives...
> 44546 primitives registered
> 1680359 vertices registered
> Building areas...
> 13602 areas built
> 2828 isles built
> Attaching islands...
> Attaching centroids...
> Number of nodes: 33748
> Number of primitives: 44546
> Number of points: 0
> Number of lines: 0
> Number of boundaries: 30931
> Number of centroids: 13615
> Number of areas: 13602
> Number of isles: 2828
> *Number of centroids outside area: 13
> Number of duplicate centroids: 108
> Number of areas without centroid: 108*
> I can remove the duplicate centroids with v.clean (using bpol) but not the
> centroids outside area.
> What would be the easiest way to remove, or at least to identify (filter
> for) and manually assess?
The reason for these problems is one step earlier. Try to densify the
vector boundaries with v.split, optionally followed by
v.build.polylines before reprojecting it. See [0] for an example of
the effect on reprojection.
Markus M
[0] http://trac.osgeo.org/grass/attachment/ticket/1918/dense_points_effect.png
> I've also tried outputting the errors using the error= command, but no
> geometries are visible in the latter.
> Cheers,
> Richard
> View this message in context: http://osgeo-org.1560.x6.nabble.com/Number-of-centroids-outside-area-difficulty-with-cleaning-tp5046717.html
> Sent from the Grass - Users mailing list archive at Nabble.com.
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
