[GRASS-user] Number of centroids outside area: difficulty with cleaning
Markus Metz
markus.metz.giswork at gmail.com
Mon Apr 15 00:35:00 PDT 2013
On Mon, Apr 15, 2013 at 5:52 AM, RichardC <richtcooper at hotmail.com> wrote:
> I tried with a length of 1000 (which I guess should represent 1000m given the
> projection is Lambert Azimuthal Equal Area) and the with a length of 500 as
> shown below in more detail. The file I'm working with quite a large
> shapefile (50MB).
> Topology of original imported shapefile (Lambert Azimuthal Equal Area):
> Attaching centroids...
> Number of nodes: 33748
> Number of primitives: 44546
> Number of points: 0
> Number of lines: 0
> Number of boundaries: 30931
> Number of centroids: 13615
> Number of areas: 13615
> Number of isles: 2817
> Topology after v.split length=500
> Number of nodes: 3274443
> Number of primitives: 3285241
> Number of points: 0
> Number of lines: 0
> Number of boundaries: 3271626
> Number of areas: 1218
> Number of isles: 0
> Number of incorrect boundaries: 3271358
> Number of centroids outside area: 12397
Very strange. v.split on the original imported shapefile (not the
reprojected vector) should not produce topological errors. Can you
make the shapefile available for testing or provide a link?
Markus M
> Topology after v.build.polylines
> v.build.polylines input=as_bas_shp_vsplit500 at PERMANENT
> output=as_bas_shp_vsplit500_vpoly
> Number of points: 0
> Number of lines: 0
> Topology after importing into CRS WGS84 (lat long)
> Number of points: 0
> Number of lines: 0
> Number of areas: 13601
> Number of isles: 2828
> *Number of incorrect boundaries: 26
> Number of centroids outside area: 14*
> If the length=1000 for v.split (then followed by v.build.polylines), then
> the toplogy after importing into WGS84:
> Number of points: 0
> Number of lines: 0
> Number of areas: 13602
> Number of centroids outside area: 13
> *Number of duplicate centroids: 109
> Number of areas without centroid: 109*
> View this message in context: http://osgeo-org.1560.x6.nabble.com/Number-of-centroids-outside-area-difficulty-with-cleaning-tp5046717p5046819.html
> Sent from the Grass - Users mailing list archive at Nabble.com.
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
