[GRASS-user] v.label text orientation
    Vincent Bain
    bain at toraval.fr
    Mon Apr 15 07:41:14 PDT 2013
Oops, I forget to say if I use v.label with -a flag, I can easily bypass
the issue by editing the label file and manually add 180° to labels I
want to flip... but it is not so easy when calling v.label with -c flag.
Vincent.
Le lundi 15 avril 2013 à 16:36 +0200, Vincent Bain a écrit :
> Hi,
> v.label allows to curl text along lines (c flag) or rotate label to
> align with line orientation (a flag). Thus labels are created in order
> to display upside-up on the map, whatever the line direction, probably
> to make text easier to read.
> When it comes to label contour lines, it can be convenient (in fact
> mandatory) to place text upside-down : conventionally figures point
> toward upslope. The trick would be to orient text in accordance with
> line direction.
> Is there an option I missed or is it simply impossible with v.label ?
> Vincent.
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
