[GRASS-user] Read GRASS vector data from mapnik
    Pietro
    peter.zamb at gmail.com
    Tue Apr 16 03:48:58 PDT 2013
On Tue, Apr 16, 2013 at 11:10 AM, Martin Landa <landa.martin at gmail.com> wrote:
>> In theory OGR support the vector format of GRASS[1].
>> There is someone that use mapnik and GRASS that know how to solve it?
> is your OGR library compiled with GRASS support?
> ogrinfo --formats
No, my OGR library was not compiled with GRASS support! :-)
sorry...
> Note that GDAL-GRASS driver needs to be updated for GRASS 7 [1].
> [1] http://trac.osgeo.org/gdal/ticket/2953
What exactly should I do?
I've downloaded the last version of gdal-svn and configured it, with:
./configure --prefix=/home/pietro/.local/ \
     --with-grass=/home/pietro/docdat/src/gis/grass/grass_trunk/dist.x86_64-unknown-linux-gnu
     --with-netcdf  \
     --with-libtiff  \
     --with-sqlite3  \
     --with-geotiff  \
     --with-python=/usr/bin/python2  \
     --without-libtool --with-curl  \
     --with-hdf5  \
     --with-geos  \
     --with-png
But compiling I got:
grass57dataset.cpp:50:38: error: declaration of C function ‘char*
GPJ_grass_to_wkt(Key_Value*, Key_Value*, int, int)’ conflicts with
          int esri_style, int prettify);
In file included from
/home/pietro/docdat/src/gis/grass/grass_trunk/dist.x86_64-unknown-linux-gnu/include/grass/gprojects.h:91:0,
                 from grass57dataset.cpp:45:
/home/pietro/docdat/src/gis/grass/grass_trunk/dist.x86_64-unknown-linux-gnu/include/grass/defs/gprojects.h:17:7:
error: previous declaration ‘char* GPJ_grass_to_wkt(const Key_Value*,
const Key_Value*, int, int)’ here
 char *GPJ_grass_to_wkt(const struct Key_Value *, const struct
Key_Value *, int, int);
ogrgrassdatasource.cpp: In member function ‘int
OGRGRASSDataSource::Open(const char*, int, int, int)’:
ogrgrassdatasource.cpp:191:28: error: ‘GV_FATAL_PRINT’ was not
declared in this scope
     Vect_set_fatal_error ( GV_FATAL_PRINT ); // Print error and continue
ogrgrassdatasource.cpp:191:43: error: ‘Vect_set_fatal_error’ was not
make[2]: *** [../o/grass57dataset.o] Error 1
make[2]: Leaving directory `/home/pietro/docdat/src/gis/gdal/frmts/grass'
make[1]: *** [grass-install-obj] Error 2
make[1]: Leaving directory `/home/pietro/docdat/src/gis/gdal/frmts'
make: *** [frmts-target] Error 2
make: *** Waiting for unfinished jobs....
make[3]: *** [../o/ogrgrassdatasource.o] Error 1
make[3]: Leaving directory
`/home/pietro/docdat/src/gis/gdal/ogr/ogrsf_frmts/grass'
make[2]: *** [grass-target] Error 2
make[2]: Leaving directory `/home/pietro/docdat/src/gis/gdal/ogr/ogrsf_frmts'
make[1]: *** [sublibs] Error 2
make[1]: Leaving directory `/home/pietro/docdat/src/gis/gdal/ogr'
make: *** [ogr-target] Error 2
Any hints?
Pietro
