[GRASS-user] Fuzzy K-mean
    Robert A Brown
    brown782 at purdue.edu
    Wed Apr 17 17:03:03 PDT 2013
I have been trying to work within the GRASS70 Command Line to interface with R. When I try to read in the rasters I get the following error:
In deleteDataset(DS) :
  Failed to delete dataset: C:\Users\....\Desktop\grass_data\PERMANENT\.tmp\unknown\nomralized_height
I navigate to the .tmp file and delete the rasters manually but I still get the same warning.
I am noticing that the R grass interface runs R in 32 bit. Is there a command to run R in 64 bit.
I notice when I run the stand alone R 64bit and use the interface to grass command:
initGRASS("C:/Program Files (x86)/GRASS GIS 7.0.svn", gisDbase="C:/Users/brown782/Desktop",location="grass_data",mapset ="PERMANENT", override=T)
R will give aforementioned error but it does read the rasters and I can do a whole suite of summary statistics.
I still have not been able to get the Fuzzy K-mean to run because the EMCluster package requires the data to be in a matrix and when I do this I am getting some strange Dimensions in R.
Any advice would as always be much appreciated
Sincerely,
Robert Brown
----- Original Message -----
To: "Robert A Brown" <brown782 at purdue.edu>, "Thomas Adams" <tea3rd at gmail.com>
Cc: grass-user at lists.osgeo.org
Sent: Thursday, April 11, 2013 8:53:42 PM
Subject: Re: [GRASS-user] Fuzzy K-mean
Tom wrote:
> I would recommend a combination of GRASS and R (http://cran.r-
> project.org/). R has fuzzy K-mean cluster capability, using
> the R addon package spgrass6 to read/write to/from GRASS and R.
see Roger's tutorial here:
 http://grasswiki.osgeo.org/wiki/R_statistics
Hamish
