[GRASS-user] GRASS6.4 Problem with v.db.addcol
Markus Neteler
neteler at osgeo.org
Sat Apr 20 08:46:55 PDT 2013
On Wed, Apr 10, 2013 at 5:58 PM, BLANDENIER Lucien
<lucien.blandenier at unine.ch> wrote:
> Dear all,
> As I explained in my previous post, I have some troubles using v.db.addcol (see below). After making different tests, I realized there is a problem using script with v.db.addcol. I tried the following script:
> #!/bin/bash
> v.db.addcol map="extracting_point_ETo_RFE_test" columns="RF_2001001 double precision" --overwrite
> And I received the following error message
> GRASS 6.4.2 (Merti_WGS84_dd)> bash list_extract_RFE.sh
> list_extract_RFE.sh: line 2: v.db.addcol: command not found
> The command is working when I write it in the shell... but I don't want to do it 2000 times!!!
I can understand :)
> Im using GRASS 6.4 on windows.
Can you please try the latest snapshot?
http://wingrass.fsv.cvut.cz/grass64/
Maybe there is a chance that it is already fixed (or can be for 6.4.3final).
Markus
