[GRASS-user] Grass7 - Inconsistencies with v.out.ogr and v.out.postgis
Mark Wynter
mark at dimensionaledge.com
Thu Apr 25 23:20:32 PDT 2013
Possibly some bugs. In summary:
CASE 1: v.out.ogr if I export to shapefile works as expected - in terms of 176783 features and SRID 2193.
CASE 2: v.out.ogr if I export to postgis, only returns 139 features, with SRID 900915(?)
CASE 3: v.out.postgis returns 176782 features, with SRID=0 despite setting SRID=2193 using the options flag.
Has anyone else encountered similar problems?
The detail...
CASE 1
v.category osm_nz_roads_2193_cleaned op=report
Layer/table: 1/grass.osm_nz_roads_2193_cleaned
type count min max
point 0 0 0
line 176783 1 88617
boundary 0 0 0
centroid 0 0 0
area 0 0 0
face 0 0 0
kernel 0 0 0
all 176783 1 88617
v.out.ogr --overwrite input=osm_nz_roads_2193_cleaned type=line dsn="PG:host=localhost dbname=test user=postgres password=password active_schema=osm" olayer=osm_nz_roads_2193_export format=PostgreSQL
Rows (estimated) 139
-- Table: osm.osm_nz_roads_2193_export
-- DROP TABLE osm.osm_nz_roads_2193_export;
CREATE TABLE osm.osm_nz_roads_2193_export
ogc_fid serial NOT NULL,
wkb_geometry geometry(LineString,900915),
cat integer,
osm_id integer,
name character varying(255),
highway character varying(255),
bridge integer,
oneway integer,
driveable integer,
trainable integer,
walkable integer,
cycleable integer,
ignore integer,
CONSTRAINT osm_nz_roads_2193_export_pk PRIMARY KEY (ogc_fid)
WITH (
OIDS=FALSE
ALTER TABLE osm.osm_nz_roads_2193_export
OWNER TO postgres;
-- Index: osm.osm_nz_roads_2193_export_geom_idx
-- DROP INDEX osm.osm_nz_roads_2193_export_geom_idx;
CREATE INDEX osm_nz_roads_2193_export_geom_idx
ON osm.osm_nz_roads_2193_export
USING gist
(wkb_geometry);
CASE 2
v.out.postgis --o input=osm_nz_roads_2193_cleaned dsn="PG:host=localhost dbname=test user=postgres password=password" olayer=osm.osm_nz_roads_2193_export options="GEOMETRY_NAME=wkb_geometry,SRID=2193"
Rows (estimated) 176782
cat integer,
osm_id integer,
bridge integer,
oneway integer,
driveable integer,
trainable integer,
walkable integer,
cycleable integer,
ignore integer,
wkb_geometry geometry(LineString),
CONSTRAINT osm_nz_roads_2193_export_pkey PRIMARY KEY (fid)
WITH (
OIDS=FALSE
OWNER TO postgres;
-- Index: osm.osm_nz_roads_2193_export_wkb_geometry_idx
-- DROP INDEX osm.osm_nz_roads_2193_export_wkb_geometry_idx;
CREATE INDEX osm_nz_roads_2193_export_wkb_geometry_idx
USING gist
(wkb_geometry);
CASE 3
v.out.ogr input=osm_nz_roads_2193_cleaned type=line dsn=/var/tmp/osm_nz_roads_export.shp
ogrinfo -so osm_nz_roads_export.shp osm_nz_roads_export
INFO: Open of `osm_nz_roads_export.shp'
using driver `ESRI Shapefile' successful.
Layer name: osm_nz_roads_export
Geometry: Line String
Feature Count: 176783
Extent: (1148817.072845, 4793789.625743) - (2089039.165212, 6193819.546965)
Layer SRS WKT:
PROJCS["Transverse_Mercator",
GEOGCS["GCS_grs80",
DATUM["New_Zealand_Geodetic_Datum_2000",
SPHEROID["Geodetic_Reference_System_1980",6378137,298.257222101]],
PRIMEM["Greenwich",0],
UNIT["Degree",0.017453292519943295]],
PROJECTION["Transverse_Mercator"],
PARAMETER["latitude_of_origin",0],
PARAMETER["central_meridian",173],
PARAMETER["scale_factor",0.9996],
PARAMETER["false_easting",1600000],
PARAMETER["false_northing",10000000],
UNIT["Meter",1]]
cat: Integer (10.0)
osm_id: Integer (10.0)
highway: String (255.0)
bridge: Integer (10.0)
oneway: Integer (10.0)
driveable: Integer (10.0)
trainable: Integer (10.0)
walkable: Integer (10.0)
cycleable: Integer (10.0)
ignore: Integer (10.0)
