[GRASS-user] r.tsunami status question
Massimiliano Cannata massimiliano.cannata at supsi.ch
Mon Apr 29 05:35:41 PDT 2013
Hello,
in attachment the code that was developed in python for grass 6.
In case you need to follows the tutorial (
http://istgeo.ist.supsi.ch/site/?q=node/4), i have also the other modules
specifically created and used for that.. (v.db.calc)
Markus: should I put it in the addons? I thougth it was once....
Best,
Maxi
On Mon, Apr 29, 2013 at 2:30 PM, Massimiliano Cannata <
massimiliano.cannata at supsi.ch> wrote:
> Hello,
> On Mon, Apr 29, 2013 at 2:25 PM, "Peter Löwe" <peter.loewe at gmx.de> wrote:
>> Michael,
>> the point of contact for r.tsunami is Maxi Cannata (cc).
>> AFAIK the development of r.tsunami continues, but the module remains to
>> be published.
>> One odler version of r.tsunami can be found in the slaxGIS - OSGeo Lab
>> 2008 special edition:
>> http://geomatica.como.polimi.it/software/vigerGIS/slaxGIS-080805/index.php?SE=osgeolab
>> FWIW, GRASS is also used to create visualisations stemming from Tsunami
>> Simulations to allow for quality checking of the models:
>>  *The FOSS GIS Workbench on the GFZ Load Sharing Facility compute cluster
>> http://de.slideshare.net/loewe/egu-2012-essi-the-foss-gis
>> *Tangible 3D printouts from GIS-Data: A work in progress report<http://ebooks.gfz-potsdam.de/pubman/item/escidoc:100081:1>
>> Kind regards,
>> Peter
>> *Gesendet:* Samstag, 27. April 2013 um 15:54 Uhr
>> *Von:* "Michael Tiemann" <mdtiemann at gmail.com>
>> *An:* loewe at gisix.com, markus.neteler at fmach.it
>> *Betreff:* r.tsunami status question
>>   I'm working on a talk and wanted to reference the GRASS project for
>> predicting tsunami inundation (disclosed at 2006 OSGEO conference).  The
>> wiki says that r.tsunami is part of the Grass Addons (
>> http://grasswiki.osgeo.org/wiki/Natural_Hazards) but when I look at the
>> SVN repository, I cannot find it either in Grass 5, 6, or 7 addon locations.
>> Using Google, I was able to find r.tsusami listed as a code sprint item
>> that perhaps was not completed.
>> Is r.tsunami dormant, renamed, or deprecated?  Thanks!
>> M
> *Massimiliano Cannata*
> Professore SUPSI in ingegneria Geomatica
> Responsabile settore Geomatica
> Istituto scienze della Terra
> Dipartimento ambiente costruzione e design
> Scuola universitaria professionale della Svizzera italiana
> Campus Trevano, CH - 6952 Canobbio
> Tel. +41 (0)58 666 62 14****
> Fax +41 (0)58 666 62 09****
> *www.supsi.ch/ist*
*www.supsi.ch/ist*
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20130429/7b04860e/attachment-0002.html>
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20130429/7b04860e/attachment-0003.html>
Type: application/octet-stream
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20130429/7b04860e/attachment-0001.obj>
