[GRASS-user] r.in.ascii - ERROR: Data conversion failed
Margherita Di Leo diregola at gmail.com
Mon Apr 29 07:39:38 PDT 2013
Hi again,
I figured out that the problem in my map was the mismatch between the
number of rows / cols given in the header and the actual number of
rows/cols. It would be nice to add a hint that comes with the error, i.e.
something like:
ERROR: Data conversion failed at row 245, col 197
Please verify that the number of rows/cols given in the header matches with
the actual number of rows/cols.
..or something like that.
Thanks and best regards.
On Mon, Apr 29, 2013 at 4:02 PM, Margherita Di Leo <diregola at gmail.com>wrote:
> Hi,
> I get the following error when trying to import a map with r.in.ascii:
> Since this error message is not very self-explanatory, anyone have idea on
> what can possibly be the problem?
> To verify if the command works, I exported and then re-imported another
> map, and everything went smooth, therefore it must be something related to
> the map that I'm trying to import..
> G6.4.3svn
> Thanks for any hint.
> Best regards,
> Margherita DI LEO
> Postdoctoral Researcher
> European Commission - DG JRC
> Institute for Environment and Sustainability (IES)
> Via Fermi, 2749
> I-21027 Ispra (VA) - Italy - TP 261
> Tel. +39 0332 78 3600
> margherita.di-leo at jrc.ec.europa.eu
> Disclaimer: The views expressed are purely those of the writer and may not
> in any circumstance be regarded as stating an official position of the
> European Commission.
Best regards,
Margherita DI LEO
Via Fermi, 2749
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20130429/37137af1/attachment.html>
