[GRASS-user] Filtering high "outliers" in Landsat reflectance imagery?
Thu Aug 1 19:21:39 PDT 2013
Eric Goddard wrote:
> Hi, I need to do the same thing to some WV-2 imagery. I'm using the command
> grass.mapcalc("$output = if($input_rast>1.0, 1.0, $input_rast)", output=wv2_out, input_rast=wv2_in)
> from python (input and output names
> changed for simplicity) but instead of replacing the values greater
> than 1 with 1, it replaces them with NaNs.  Is there something wrong
> with my mapcalc expession?
No.
Is there anything unusual about the actual map names? Names containing
any of the characters
need to quoted.
