[GRASS-user] Opening a shape file in GRASS 6.4.3
Markus Neteler
neteler at osgeo.org
Sun Aug 18 15:28:11 PDT 2013
I tried your data with GRASS 7:
# create location from SHP file:
grass70 -c Meghalay.shp grassdata/Meghalay
# import, here the final "working" command line:
v.in.ogr Meghalay.shp out=Meghalay snap=100
Given that such "severe" snapping was needed (snapping is in map
units, here: meters), you will need to redo the conversion from KML
since the geometry in the SHAPE file is broken as the others
indicated.
Markus
