[GRASS-user] osgeo4w-64bit (with winGRASS-64bit) - testing welcome
Saulteau Don sault.don at gmail.com
Mon Aug 26 09:30:00 PDT 2013
I get the same error on Windows 8 64-bit when starting grass.
I uninstalled the old osgeo4w (32bit) and removed the folder in C:\
before installing the 64-bit version.
Donovan
On Sun, Aug 25, 2013 at 2:50 PM, Jürgen E. <jef at norbit.de> wrote:
> Hi Markus,
> On Sun, 25. Aug 2013 at 23:40:25 +0200, Markus Neteler wrote:
>> On Sun, Aug 25, 2013 at 9:53 PM, Helmut Kudrnovsky <hellik at web.de> wrote:
>> > from the osgeo4w-ML, please test also winGRASS6.4.3-64bit
>> Ver nice and thanks for the efforts to Juergen et al.
>> It seems that the 32bit OSGeo4W needs to be removed first (right?).
> Right, don't mix the installs.  You can install both, but not to the same
> directory  - new installer has also an option to specify different start menu
> names so that the menu entries of multiple install don't overwrite each other.
>> I notice that it uses C:\Windows\system32\cmd.exe to fire up GRASS 64bit,
>> perhaps that's the reason?
> On 64bit windows that's the 64bit cmd - the 32bit cmd is in syswow64.
> Jürgen
> Jürgen E. Fischer         norBIT GmbH               Tel. +49-4931-918175-31
> Dipl.-Inf. (FH)           Rheinstraße 13            Fax. +49-4931-918175-50
> Software Engineer         D-26506 Norden               http://www.norbit.de
> norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
> Rheinstrasse 13, 26506 Norden
> GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
