[GRASS-user] Duplicated CAT during import
Markus Neteler
neteler at osgeo.org
Sat Aug 31 10:09:58 PDT 2013
On Sat, Aug 31, 2013 at 7:06 PM, Paolo Cavallini <cavallini at faunalia.it> wrote:
> -----BEGIN PGP SIGNED MESSAGE-----
> Hash: SHA1
> Il 31/08/2013 14:04, Markus Neteler ha scritto:
>> I'm encountering problems with subsequent v.overlay, and I suspect duplicated CATs
>> may be the cause.
>>> can you please post the relevant column info output of "ogrinfo yourmap"?
> which map? The original before import?
Yes.
> Here it is:
> Layer name: test_import
> Geometry: Polygon
> Feature Count: 2
> COD_COMPON: String (6.0)
> COMPONENTE: String (200.0)
> COD_SUB_CO: String (10.0)
> SUB_COMPON: String (200.0)
> NUM_ELEMEN: String (4.0)
> NUM_SIST_E: Integer (10.0)
> NUM_TAV: Real (24.5)
> NORMA: String (200.0)
> SCHEDA: String (200.0)
> ID1: Integer (10.0)
I don't see any existing "cat" column there.
What should be duplicated?
Markus
