[GRASS-user] i.maxlik can't read signature from i.class
Cesar Augusto Ramírez Franco caesarivs at gmail.com
Tue Dec 3 05:29:30 PST 2013
Hello Markus, thanks for your response
I've tried deleting the signature from the ASCII file and doing the i.class
again, I've tried deleting the signature file and creating it again, but I
always get a kind of empty file:
GRASS (MAPSET: landsat - LOCATION:
nc_spm_08):~/grassdata/nc_spm_08/landsat/group/lsat7_2000_RGB/subgroup/lsat7_2000_RGB/sig
> cat classlsat7
#vegetation
244
#construction
445
#water
399
I have 6.4.2 from debian stable (wheezy) repos, I haven't tried compiling
svn stable, but I tried 6.4.3 on Linux Mint on a VM and I got the same
results.
It worked with the new module on 7svn flawlessly though
2013/12/2 Markus Neteler <neteler at osgeo.org>
> Hello Cesar,
> On Tue, Nov 26, 2013 at 4:47 PM, Cesar Augusto Ramírez Franco <
> caesarivs at gmail.com> wrote:
>> Hello everyone,
>> I've been trying to do a supervised classification from landsat8 imagery
>> using i.class and then i.maxlik, but I'm getting an error when running
>> i.maxlik saying it can't read the signature file.
>> I tested my procedure on the NC sample dataset and I'm getting the same
>> error, I'm using Grass 6.4.2 on Debian Wheezy, installed from the debian
>> repo. Here's the command set:
>> #Display RGB enhanced map
>> i.landsat.rgb blue=lsat7_2000_10 green=lsat7_2000_20 red=lsat7_2000_30
>> d.rgb blue=lsat7_2000_10 green=lsat7_2000_20 red=lsat7_2000_30
>> #"Real color" map
>> r.composite red=lsat7_2000_30 green=lsat7_2000_20 blue=lsat7_2000_10
>> output=lsat7_2000_RGB
>> #Group images to process
>> i.group group=lsat7_2000_RGB subgroup=lsat7_2000_RGB
>> input=lsat7_2000_10,lsat7_2000_20,lsat7_2000_30
>> #Unsupervised classification
>> i.cluster group=lsat7_2000_RGB subgroup=lsat7_2000_RGB sigfile=clustlsat7
>> classes=20 report=rep_clust_lsat7.txt
>> i.maxlik group=lsat7_2000_RGB subgroup=lsat7_2000_RGB sigfile=clustlsat7
>>  class=lsat7_classes reject=lsat7_classes_rej
>> #Supervised classification
>>  i.class map=lsat7_2000_RGB group=lsat7_2000_RGB subgroup=lsat7_2000_RGB
>> outsig=classlsat7
>> i.maxlik group=lsat7_2000_RGB subgroup=lsat7_2000_RGB sigfile=classlsat7
>> class=lsat7_class_sup
> I reproduced your example here (thanks for providing it, makes testing
> easy!).
>> Here I get the error in which i.maxlik can't read the signature file
>> created by i.class (classlsat7) but read the one created by i.cluster
>> flawlessly
> Here it went through (Fedora 19 64bit, 6.4.4svn).
> GRASS 6.4.4svn (nc_spm_08):~ > i.class map=lsat7_2000_RGB
> group=lsat7_2000_RGB subgroup=lsat7_2000_RGB outsig=classlsat7
> RESULT SIGNATURE
> GRASS 6.4.4svn (nc_spm_08):~ > i.maxlik group=lsat7_2000_RGB
> subgroup=lsat7_2000_RGB sigfile=clustlsat7  class=lsat7_classes
> reject=lsat7_classes_rej --o
>  100%
>>  This is what I'm selecting on the i.class monitor, I named it
>> vegetation:
> My map looked similar.
>> And the contents of the classlsat7 signature file are the following:
>> #vegetation
>> 166
> This is strange... Here I get
> GRASS 6.4.4svn
> (nc_spm_08):~/grassdata/nc_spm_08/landsat/group/lsat7_2000_RGB/subgroup/lsat7_2000_RGB/sig
> > cat classlsat7
> #lake
> 899
> 68.2458 49.1224 38.317
> 2.30345
> 1.26392 2.63753
> 1.82294 2.67163 5.90938
> #vegetation
> 92
> 76.3804 66.6957 57.2391
> 120.414
> 116.029 116.236
> 160.886 158.447 222.206
> Maybe you remove the unfortunate signature from the ASCII file and
> digitize it again?
> Best,
> Markus
*César Augusto Ramírez Franco*
Laboratorio de Sistemas Complejos Naturales
Escuela de Geociencias
Facultad de Ciencias
Universidad Nacional de Colombia - Sede Medellín
Teléfono: (57-4) 430 9369 - 301 389 5607
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20131203/ea6f0d12/attachment-0001.html>
