[GRASS-user] want to color vector map. What am I doing wrong?
Anna Petrášová
kratochanna at gmail.com
Tue Dec 3 13:25:38 PST 2013
Hi Michael,
On Tue, Dec 3, 2013 at 4:12 PM, Michael Barton <Michael.Barton at asu.edu>wrote:
> I want to color a vector map. I’m just trying it with some test maps from
> the North Carolina demo set. I used the ‘manage color rules interactively’
> dialog in the GUI and am using a version of GRASS 7 compiled on 1 November.
I think it's currently somehow broken due to some other changes in GUI
which were not reflected in this dialog. I will try to fix it, probably in
the next weeks. I will actually need this functionality, too.
> Is there no way to use a character column for colors?
I think it requires numbers but I am not sure if it is the problem of GUI
or underlying module (the latter I guess).
Anna
> Even when I use a numeric column (e.g., the column “pumpers” in the
> firestations vector points map), the OK, apply, and preview buttons remain
> greyed out after I have filled out the table with values and colors. I’ve
> tried each of the integer values in the column and using the min and max
> values only. Yes, each of the table lines is checked.
> I thought that maybe this only works for area maps. But I have the same
> problems with them. (I tried the geology map).
> Clicking the “add column” button does nothing AFAICT
> I also tried the v.colors approach. I was able to do everything (no
> greyed out buttons). But no colors either.
> So what am I doing wrong? Making colored thematic maps is a pretty basic
> and important function. I didn’t try the thematic map layer because I
> wanted to do points too and it only does areas.
> Michael
> ______________________________
> C. Michael Barton
> Director, Center for Social Dynamics & Complexity
> Professor of Anthropology, School of Human Evolution & Social Change
> Arizona State University
> Tempe, AZ 85287-2402
> USA
> voice: 480-965-6262 (SHESC), 480-965-8130/727-9746 (CSDC)
> fax: 480-965-7671(SHESC), 480-727-0709 (CSDC)
> www: http://csdc.asu.edu, http://shesc.asu.edu
> http://www.public.asu.edu/~cmbarton
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20131203/5554b006/attachment.html>
