[GRASS-user] Cannot change directory via GRASS command console
Paul Brewin PBrewin at fisheries.gov.fk
Thu Dec 5 05:04:57 PST 2013
Dear List - I am having difficulties with the below script, and it seems to be because there is a possible bug in the the GRASS installation that comes bundled with QGIS2.
To synthesis the problem, through the GRASS command console, I can't seem to change directory.  After launching GRASS, typing DIR or LS produces the contents of C:\PROGRA~1\QGISDU~1\bin.  Then I type cd <D:/....../raw_data> to change directory and point GRASS to where my data is stored (and to the directory where gdal_translate writes processed tiff files) - this runs without error.  However, typing LS or DIR then still show the original C:/ directory.
I can run the below script, gdal_translate finds the raw files in the C:/ directory, r.in.gdal finds the processed files in the C:/ directory, and places them in the correct MAPSET.   But its not ideal to have to load my C:/....bin directory with hundreds of raw files, then have it filled with processed files, etc.  I think this is having other down-stream effects on how GRASS works when I want to start working with my imported layers.
I've talked to a few unix people here and they're stumped.  I've also scoured the GRASS environment variables and online help.  I'm using the GRASS 6.4 bundled with QGIS2, on Windows 7.  It would be great if someone could check if this CD issue is common to other's similar installations, and if not, suggest what might be wrong with my system.
Thanks,
Paul.
From: grass-user-bounces at lists.osgeo.org [mailto:grass-user-bounces at lists.osgeo.org] On Behalf Of Paul Brewin
Sent: 03 December 2013 09:33
To: grass-user at lists.osgeo.org
Subject: [GRASS-user] Help: cannot change directory in GRASS - QGIS installation
Hello,  I can't seem to change the search path in GRASS 6.4.3, Windows 7, installed with the QGIS 2.0 bundle.  To walk through my steps so far...
I have a bash script example below called myscript.sh.  It comes from http://grasswiki.osgeo.org/wiki/MODIS#MODIS_Aqua
#!/bin/sh
for file in A*SST_4 ; do
    echo "map: $file"
    gdal_translate -a_srs "+init=epsg:4326" -a_nodata 65535 \
    -a_ullr -180 90 180 -90 -co "COMPRESS=PACKBITS" \
    HDF4_SDS:UNKNOWN:"$file":0 ${file}_prep.tif
    r.in.gdal in=${file}_prep.tif out=$file
done
The script and data files (with the pattern A*SST_4) are stored in  <D:/....../raw_data>. To run the script in the GRASS command console I use
sh D:/...../raw_data/mystript.sh
This does not work, and I see that its because the data files can't be found.  So using DIR in the GRASS command console reveals that the search path is C:\PROGRA~1\QGISDU~1\bin
In the GRASS command console I then type cd D:/....../raw_data, with no errors.  However, typing DIR or LS in the command line shows that I'm still in C:\...\bin
I can make this work by simply copying the data files to the C:\...\bin directory, but its not ideal as the processed files (the ${file}_prep.tif bit) end up in the C:\ directory.  I can also modify the <for> loop by adding the full file path, but as you can see, that breaks the script at the r.in.gdal line because r.in.gdal then tries to create a db in my Mapset that has a huge directory path in the name ($file), which is not allowed.
I think there are other issues, for example when I run the script using the C:/ as above, it adds the db to my Mapset (I can see it with r.info), but I then can't seem to add them as layers.
Very long winded, but the I think the basic problem is that I can't change the path.  Launching GRASS as administrator does not help.   Ultimately, I'd like to process the raw modis files, add them to my mapset, and view the layer.  Working through the rest of the example in  http://grasswiki.osgeo.org/wiki/MODIS#MODIS_Aqua also falls over when I get to the Set Colours section with <palette_sst.gcolors> also because I think the path is not correct.
Thanks for your help!
Paul
______________________________________________________________________
This email has been scanned by the Symantec Email Security.cloud service.
For more information please visit http://www.symanteccloud.com
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20131205/852bfe77/attachment.html>
