[GRASS-user] grass70 problem with gui
Anna Petrášová kratochanna at gmail.com
Tue Dec 10 09:28:54 PST 2013
On Tue, Dec 10, 2013 at 12:17 PM, Martin Landa <landa.martin at gmail.com>wrote:
> Hi,
> 2013/12/10 Ahmadou Dicko <dicko.ahmadou at gmail.com>:
> > I used to compile it from trunk without problem in ArchLinux but since
> this
> > morning I have the same error message.
> > g.version -g
> > version=7.0.svn
> > date=2013
> > revision=58433
> > build_date=2013-12-10
> > Are there any workaround ?
> I see, generating XML menu files seems to fail. At least on my PC
> Generating interface description for all modules...
> GISRC=/opt/src/grass_trunk/dist.x86_64-unknown-linux-gnu/demolocation/.grassrc70
> GISBASE=/opt/src/grass_trunk/dist.x86_64-unknown-linux-gnu
> PATH="/opt/src/grass_trunk/dist.x86_64-unknown-linux-gnu/bin:/opt/src/grass_trunk/dist.x86_64-unknown-linux-gnu/bin:/opt/src/grass_trunk/dist.x86_64-unknown-linux-gnu/scripts:$PATH"
> PYTHONPATH="/opt/src/grass_trunk/dist.x86_64-unknown-linux-gnu/etc/python:/opt/src/grass_trunk/dist.x86_64-unknown-linux-gnu/etc/python:$PYTHONPATH"
> LD_LIBRARY_PATH="/opt/src/grass_trunk/dist.x86_64-unknown-linux-gnu/bin:/opt/src/grass_trunk/dist.x86_64-unknown-linux-gnu/lib:/opt/src/grass_trunk/dist.x86_64-unknown-linux-gnu/lib:/opt/src/grass_trunk/dist.x86_64-unknown-linux-gnu/lib"
> LC_ALL=C python tools/build_modules_xml.py >
> /opt/src/grass_trunk/dist.x86_64-unknown-linux-gnu/etc/gui/wxpython/xml/module_items.xml
> Traceback (most recent call last):
>   File "tools/build_modules_xml.py", line 148, in <module>
>     sys.exit(main())
>   File "tools/build_modules_xml.py", line 133, in main
>     header(fh)
>   File "tools/build_modules_xml.py", line 94, in header
>     (vInfo['version'].split('.')[0],
> KeyError: 'version'
> Unfortunately these kind of errors are not reported in error.log
> (TODO: should be fixed).
> Will have time to check it later unfortunately. Martin
g.version -r is crashing for me, I just realized it.
Anna
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20131210/48cfd43b/attachment.html>
