[GRASS-user] Interpolation with v.surf.rst
    Martin Landa
    landa.martin at gmail.com
    Sun Feb  3 03:47:17 PST 2013
2013/1/16 Margherita Di Leo <diregola at gmail.com>:
>> > If you want to use elevation values from zcolumn, you should not use
>> > the -z flag. Try instead
>> > v.surf.rst input=isoline at TOPOIKDATA zcolumn=height elev=elev_1m
>> I was thinking to omit such -z flags in G7.
>> * if zcolumn is given, use values from this column
>> * if zcolumn is *not* given use z coordinates (if vector is 2D, print
>> error).
done in r54865. Testing welcomed.
* if input is 3D and zcolumn is not given -> using z-values
* if input is 3D and zcolumn is given -> using attributes
* if input is 2D and zcolumn is not given -> using categories
* if input is 2D and zcolumn is given -> using attributes
Martin
Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
