[GRASS-user] Count points in a network between two locations
    Markus Metz
    markus.metz.giswork at gmail.com
    Mon Feb  4 08:17:39 PST 2013
On Mon, Feb 4, 2013 at 5:01 PM, Markus Metz
<markus.metz.giswork at gmail.com> wrote:
> On Mon, Feb 4, 2013 at 4:41 PM, Moritz Lennert
> <mlennert at club.worldonline.be> wrote:
>> On 04/02/13 16:07, Markus Metz wrote:
>>> On Mon, Feb 4, 2013 at 3:41 PM, Moritz Lennert
>>>> Now I get a segfault. gdb full backtrace and DEBUG=3 log attached. Do you
>>>> need something else ?
>>> Should be fixed in r54897.
>> The module runs now and very fast, but weirdly enough I cannot display the
>> category values in the resulting map. Using wxgui, I get
>> The command 'd.vect map=allpairs at user1 type=point,line,area,face
>> display=shape,cat' has failed
>> The same for
>> d.vect map=allpairs at user1 layer=1 type=line display=shape,cat
>> Trying to run this on the command line:
>> d.mon cairo
>> Gives me a seg fault at
>> Debug=3:
>> D3/3: cat lab: field = 1, cat = 1121
>> D3/3: Vect_read_next_line(): next_line = 53
>> D3/3: V2_read_next_line_nat()
>> D3/3: Vect__Read_line_nat: offset = 95566
>> D3/3:     type = 2, do_cats = 1 dead = 0
>> D3/3:     n_cats = 96
>> D3/3:     n_points = 41
>> Erreur de segmentation
>> gdb:
>> Program received signal SIGSEGV, Segmentation fault.
>> dig_alloc_points (points=0x313231, num=42) at struct_alloc.c:338
>> 338         alloced = points->alloc_points;
> The segfault is caused by d.vect because the maximum text length is
> 100 characters only !!! I'm going to fix it.
Fixed in r54906.
>> Looking at the map I do get out of the operation (attached) I would think
>> that the list of cats for a given segment might just be too long... I guess
>> my idea was maybe not so wise and your original implementation was actually
>> better.
It displays now correct, but "correct" means long read lines with
category numbers. Actually, the display would look the same with
duplicate lines.
Markus M
