[GRASS-user] Map display does not open at start
Daniel Victoria daniel.victoria at gmail.com
Tue Feb 5 05:47:11 PST 2013
You can download the location from
https://dl.dropbox.com/u/19035357/corr_Atm_utm23s.zip
It has one band of a landsat TM5 image. The zip file is 17Mb. Works fine in
Grass 7.0.svn
Grass 6.4.3RC2 and 6.4.3svn do not like it.
Cheers
Daniel
On Tue, Feb 5, 2013 at 11:09 AM, Martin Landa <landa.martin at gmail.com>wrote:
> Hi,
> 2013/2/5 Daniel Victoria <daniel.victoria at gmail.com>:
> > I just installed 6.4.3svn-r54899-492 from OSGeo4W and I get the same
> error.
> > Grass GIS Map Display:1 will not open. I'm using the same location that
> > works fine with grass 7.
> I cannot reproduce it with NC dataset, can you send me sample location
> for which wxGUI fails.
> Thanks, Martin
> Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20130205/9966c213/attachment.html>
