[GRASS-user] R.denoise
    Nikos Alexandris
    nik at nikosalexandris.net
    Sat Feb  9 01:31:27 PST 2013
Garcia Prieto wrote:
> After same struggle I managed to start r.denoise, but I received this
> strange message. any idea?
> (Thu Feb  7 18:59:04 2013)
> r.denoise --verbose input=MDE_EM_UTM_WGS84 at PERMANENT
> output=Denoised_MDE_EM_UTM_WGS84 Exporting points...
Not sure -- maybe the above instructions are not enough.  Please have a look
at the thread which Helmut K pointed (other post), and in the manual:
NOTES
r.denoise works with a cartesian coordinate system. Thus data in geographic
(lat-long) coordinates require projection during processing. The script is
able to do this if the EPSG code of a suitable coordinate system is provided.
As from the data names, they seem to projected in UTM.  It should work!  Maybe
specify, in addition an "epsg=EPSGofSomeProjection" for the region/country in
which you are working on?
Ah, and don't forget: RAM capacity of your system is, I guess, critical.
Please, let us know how it works.
Thank you, Nikos
Desc: This is a digitally signed message part.
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20130209/44263e85/attachment.pgp>
