[GRASS-user] i.maxlik
Johannes Radinger
johannesradinger at gmail.com
Wed Feb 13 03:27:04 PST 2013
Hi
On Wed, Feb 13, 2013 at 10:36 AM, Rebecca Stedham
<rlstedham at btinternet.com> wrote:
> Hello,
> I am running i.maxlik in python - attempting to automate a processing chain.
> I use the command:
> grass.run_command('i.maxlik', group= group, subgroup=subgroup,
> class='classification', sigfile = sigfile, verbose = True)
> Infuriatingly, however 'class' is a python keyword and it doesn't run due to
> 'invalid syntax'.
I had a similar issue with v.distance which uses 'from', another python keyword.
Here the pythoncode is '_from' which looks like:
grass.run_command("v.distance",_from="xxx",to="xxx",...)
Maybe there is something similar for class ('_class'?) in i.maxlik.
/johannes
> Would you know a way to work around this?
> Regards
> Becky
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
