[GRASS-user] Script i.histo.match
PrusovaM at email.cz
Fri Feb 15 05:22:14 PST 2013
Hi everybody,
I have problem with i.histo.match.py in GRASS on Ubuntu.
I have downloaded i.histo.match. py from
https://svn.osgeo.org/grass/grass-addons/grass7/imagery/i.histo.match/
I tried to run the script by command: python i.histo.match.py, but it doesn'
t work.
I have GRASS 6.4.1. and error messsage is:
GRASS 6.4.1 (barvy):~ > python Stažené/i.histo.match.py
Unknown command "option G_OPT_R_INPUTS" at line 25
Unknown command "description" at line 26
Unknown command "required" at line 27
Unknown command "end" at line 28
Unknown command "option G_OPT_R_OUTPUT" at line 29
Unknown command "description" at line 30
Unknown command "required" at line 31
Unknown command "answer" at line 32
Unknown command "end" at line 33
Unknown command "option G_OPT_DB_DATABASE" at line 34
Unknown command "required" at line 35
Unknown command "answer" at line 36
Unknown command "end" at line 37
File "/usr/lib/grass64/etc/wxpython/gui_modules/menuform.py", line
2207, in <module>
task = grassTask(cmd[0])
361, in __init__
processTask(tree =
etree.fromstring(getInterfaceDescription(grassModule)),
1970, in getInterfaceDescription
"Details: %s") % (cmd, e.value)
AttributeError: 'exceptions.OSError' object has no attribute 'value'
I search something about this problem and I find information about
GRASS 7 and their new modules for python. I install GRASS 7, but this
version gives error message:
Starting GRASS GIS...
File "/usr/local/grass-7.0.svn/etc/gui/wxpython/gis_set.py", line 36, in
<module>
from core import globalvar
File "/usr/local/grass-7.0.svn/etc/gui/wxpython/core/globalvar.py", line
28, in
<module>
from core.debug import Debug
File "/usr/local/grass-7.0.svn/etc/gui/wxpython/core/debug.py", line 67,
in
<module>
Debug = DebugMsg()
File "/usr/local/grass-7.0.svn/etc/gui/wxpython/core/debug.py", line 38,
in
__init__
self.SetLevel()
File "/usr/local/grass-7.0.svn/etc/gui/wxpython/core/debug.py", line 43,
in
SetLevel
self.debuglevel = int(grass.gisenv().get('WX_DEBUG', 0))
File "/usr/local/grass-7.0.svn/etc/python/grass/script/core.py", line
735, in gisenv
s = read_command("g.gisenv", flags='n')
File "/usr/local/grass-7.0.svn/etc/python/grass/script/core.py", line 278,
in read_command
ps = pipe_command(*args, **kwargs)
File "/usr/local/grass-7.0.svn/etc/python/grass/script/core.py", line 255,
in pipe_command
return start_command(*args, **kwargs)
File "/usr/local/grass-7.0.svn/etc/python/grass/script/core.py", line 217,
in start_command
return Popen(args, **popts)
File "/usr/local/grass-7.0.svn/etc/python/grass/script/core.py", line 56,
in
__init__
startupinfo, creationflags)
File "/usr/lib/python2.7/subprocess.py", line 679, in __init__
errread, errwrite)
File "/usr/lib/python2.7/subprocess.py", line 1249, in
_execute_child
raise child_exception
OSError: [Errno 2] No such file or directory
Error in GUI startup. If necessary, please report this error to the GRASS
developers.
Switching to text mode now.
I have python version 2.7 and 3.
I find this comunication http://osgeo-org.1560.n6.nabble.com/OSError-
importing-CSV-file-with-a-Python-Script-td4998910.html
But I don't underestand - Can I copy this environment variables and paste to
the .bashrc?
Thank you
Marketa Prusova
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20130215/596fda6c/attachment.html>
