[GRASS-user] getting from DBF to SQLite
    Markus Metz
    markus.metz.giswork at gmail.com
    Fri Feb 15 08:29:53 PST 2013
On Fri, Feb 15, 2013 at 8:21 AM, Micha Silver <micha at arava.co.il> wrote:
> On 15/02/2013 01:42, Hamish wrote:
> Markus Metz wrote:
> In GRASS 6.4.1- it was possible to have a separate sqlite db
> for each vector in $MAPSET/vector/$MAP/sqlite.db. I have no
> idea why this option has been disabled. The VAR file can be
> DB_DRIVER: sqlite
> DB_DATABASE:
> $GISDBASE/$LOCATION_NAME/$MAPSET/vector/$MAP/sqlite.db
> Should we revert the changes that make it now impossible to
> have a separate sqlite db for each vector?
> AFAIK it's still possible to have a separate sqlite db for each
> vector if you use v.db.connect (see v.pack.py), it's just that
> you can't tell db.connect to make that the default for all new
> maps.
> perhaps if [v.]db.connect understood to parse '$MAP' you could
> have a portable
> database='$GISDBASE/$LOCATION_NAME/$MAPSET/vector/$MAP/sqlite.db'
> string saved in the VAR file? (and so, by default but user-
> alterable, all sqlite layers for that map saved in the same file)
> "db.sqlite" or "sqlite.db" for the filename?
> If the $MAP variable is available, I'd like to see the database names as
> '$GISDBASE/$LOCATION_NAME/$MAPSET/vector/sqlite/$MAP.sqlite'
This could cause problems with SQLite directory locking because of
[0]. Therefore I would prefer to restore the previous behaviour of
allowing '$GISDBASE/$LOCATION_NAME/$MAPSET/vector/$MAP/sqlite.db
Markus M
[0] http://www.sqlite.org/lockingv3.html
> and I think you're suggestion to put all layers for a vector into one sqlite
> file does make sense. THere are definitely situations where you want to join
> between different layers within the same vector. Having both in the same
> sqlite makes that easier.
> Hamish
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
> This mail was received via Mail-SeCure System.
> Micha Silver
> GIS Consulting
> 052-3665918
> http://www.surfaces.co.il
