[GRASS-user] Importing ESRI Shapefile might cause attribute data corruption
Benjamin Ducke benducke at fastmail.fm
Mon Feb 18 09:06:18 PST 2013
Maris,
This sounds a like a truly horrible problem.
Thanks for raising awareness of this.
Are there any other sources on the web where
it would be possible to get more information
about this?
Have you tried downgrading only the Shapefile
drivers in the GDAL 1.9.x release?
Best,
Ben
On 02/15/2013 05:01 PM, Maris Nartiss wrote:
> JFYI
> GRASS is also hit hard by recent GDAL/OGR ESRI Shapefile encoding
> saga. Importing ESRI Shapefile with non-latin text most likely will
> corrupt Your text.
> Symptoms - even when setting correct encoding for wxgui in
> preferences, non-latin letters are shown grabbled and doubled (two
> garbage symbols instead of a single letter).
> Solution - create a .cpg file and pray or downgrade GDAL/OGR on
> pre-1.9.0 version (not an option for WinGRASS users).
> Note - if Your data are corrupted during import with v.in.ogr, there's
> no easy way how to correct it.*
> * find/replace in LO Calc might do the trick for DBF file.
> Have a nice day.
> Maris.
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
Benjamin Ducke
{*} Geospatial Consultant
{*} GIS Developer
