[GRASS-user] Bar in ps.map
Hamish hamish_b at yahoo.com
Sat Feb 23 23:12:19 PST 2013
Moritz:
> AFAIK, the only way currently possible is to create
> your bar charts separately as eps files and to include
> them into your ps.map call using the eps parameter in the
> vpoints command.
probably a nice tip/example to put in the ps.map wiki pages?
by the way/for the record, for the display monitors d.vect.chart
can do both the bar charts and bubble plots, but now d.vect
can do bubble charts too.
the ps.map vpoints sizecolumn instruction allows you to make
bubble plots there (I'm not sure if your example used that or
not). The vpoints rotatecolumn can also be useful for point
symbols, and color from rgbcolumn. I'm pretty sure I haven't
coded in the primary/secondary color scheme for symbols that
d.vect uses yet, which will improve the rgbcolumn support
automagically.
Hamish
