[GRASS-user] "v.transform" reports erroneous values in the transformation matrix
José María Michia Roberts
jose.maria.michia at gmail.com
Tue Feb 26 05:17:23 PST 2013
Hi all!
I've found that values of transformation matrix reported by
v.transform are erroneous after using this values in ST_Affine (a
PostGIS's function).
The values that seems to be erroneous are x_offset and y_offset. The
rotation values seems to are fine.
The transformed elements are ok (it is, their coordinates are in the
right place).
Values reported by v.transform:
xoff = -139153.031250
yoff = 8352534.450195
The correct values must be (aproximately):
xoff = 5461371
yoff = 6321181
The complete session's log with one test element is there (same
results with a whole layer):
http://pastebin.com/FUtnePvb
Local map: tmp
Transformed map: tmp_geo
Take a look at the map region for tmp/tmp_geo (reported by v.info),
and compare these values with those of x_off / y_off (reported by
v.transform).
Maybe I'm not interpreting this correctly.
Thanks all!
Jose
