[GRASS-user] Geomorphons and extension manager
Robert Andrew Brown
brown782 at purdue.edu
Tue Feb 26 12:14:27 PST 2013
Thank you.
I am thinking about trying to re-compile GRASS from source code and see if it will resolve the issue. Also, I found some documentation on using python to acquire add-ons with the g.extension manager.
Sincerely,
-robert brown
On Feb 26, 2013, at 1:40 PM, Michael Barton <Michael.Barton at asu.edu> wrote:
> I'm having similar problems with the extension manage on the Mac currently and filed a bug report.
> Michael
> ______________________________
> C. Michael Barton
> Director, Center for Social Dynamics & Complexity
> Professor of Anthropology, School of Human Evolution & Social Change
> Arizona State University
> Tempe, AZ 85287-2402
> USA
> voice:
> 480-965-6262 (SHESC), 480-727-9746 (CSDC)
> fax: 480-965-7671(SHESC), 480-727-0709 (CSDC)
> www:
> http://csdc.asu.edu, http://shesc.asu.edu
> http://www.public.asu.edu/~cmbarton
> On Feb 26, 2013, at 10:40 AM, <grass-user-request at lists.osgeo.org>
> wrote:
>> From: Robert Andrew Brown <brown782 at purdue.edu>
>> Subject: [GRASS-user] Geomorphons and extension manager
>> Date: February 26, 2013 10:20:42 AM MST
>> To: <grass-user at lists.osgeo.org>
>> Cc: Phillip Owens <prowens at purdue.edu>
>> To whom it may concern,
>> I am trying to use extension manager in grass to install geomrphons. However, I am having trouble with the extension manager(error below). I emailed the geomorphon developer Jarek Jasiewicz(See Below) and he suggest I contact the GRASS-Users forum.
>> Please advise,
>> -Robert Brown
>>> From: JASIEWICZ Jarosław <jarekj at amu.edu.pl>
>>> Subject: Re: Geomorphons
>>> Date: February 26, 2013 11:56:20 AM EST
>>> To: brown782 at purdue.edu
>>> On 02/26/2013 05:21 PM, brown782 at purdue.edu wrote:
>>>> Dear Sir,
>>>> I use grass on my Mac OS X 10.8.2. I have been trying to compile grass to install the add-on Geomorphons. However, it is overwhelming to compile grass from source code as I have very little experience compiling programs. When I saw that your Geomorphons algorithm was part of the grass 7.0 add-ons I was pleased and tried to use the extension manager to add it to my grass add-on repository, however, I get an several errors which I have posted below. Any Suggestions?
>>>> g.extension extension=r.geomorphon/ operation=add
>>>> Fetching <r.geomorphon/> from GRASS-Addons SVN (be patient)...
>>>> Compiling...
>>>> In file included from geom.c:1:
>>>> local_proto.h:1:20: error: stdlib.h: No such file or
>>>> directory
>>>> local_proto.h:2:20: error: string.h: No such file or
>>>> directory
>>>> local_proto.h:3:18: error: math.h: No such file or directory
>>>> local_proto.h:4:27: error: grass/glocale.h: No such file or
>>>> directory
>>>> local_proto.h:5:23: error: grass/gis.h: No such file or
>>>> directory
>>>> local_proto.h:6:26: error: grass/raster.h: No such file or
>>>> directory
>>>> local_proto.h:56: error: expected specifier-qualifier-list
>>>> before 'RASTER_MAP_TYPE'
>>>> local_proto.h:66: error: expected specifier-qualifier-list
>>>> local_proto.h:74: error: expected specifier-qualifier-list
>>>> before 'CELL'
>>>> local_proto.h:139: error: expected declaration specifiers or
>>>> '...' before 'RASTER_MAP_TYPE'
>>>> local_proto.h:140: error: expected ')' before '*' token
>>>> geom.c: In function 'exposition':
>>>> geom.c:146: warning: incompatible implicit declaration of
>>>> built-in function 'fabs'
>>>> geom.c: In function 'extends':
>>>> geom.c:206: warning: incompatible implicit declaration of
>>>> geom.c: In function 'shape':
>>>> geom.c:232: warning: incompatible implicit declaration of
>>>> built-in function 'atan'
>>>> geom.c:236: warning: incompatible implicit declaration of
>>>> built-in function 'sin'
>>>> geom.c:237: warning: incompatible implicit declaration of
>>>> built-in function 'cos'
>>>> directory
>>>> directory
>>>> directory
>>>> directory
>>>> directory
>>>> before 'CELL'
>>>> lipo: can't figure out the architecture type of: /var/folder
>>>> s/wc/2dv9njw93k3bfyy5ppkw022h0000gn/T//ccESKY4a.out
>>>> make: *** [OBJ.x86_64-apple-darwin12.2.0/geom.o] Error 1
>>>> ERROR: Compilation failed, sorry. Please check above error messages.
>>>> (Tue Feb 26 09:40:18 2013) Command finished (3 sec)
>>>> Your help is much appreciated!
>>>> Sincerely,
>>>> Robert Brown
>>> All messages comes from compiler informing you haven't installed standard librarires. This is however the issue of g.extension, which do not work well with Apple systems. Please contact grass dev team how to resolve this issue
>>> regards
>>> Jarek
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20130226/51dd1782/attachment-0001.html>
