[GRASS-user] Geomorphons and extension manager
    Moskovitz, Bob@DOC
    Bob.Moskovitz at conservation.ca.gov
    Tue Feb 26 15:38:43 PST 2013
When I tried to compile r.geomorphon, I got the errors you see below.  I just tried g.extensions with similar results.
$ make MODULE_TOPDIR=/home/bob/dev/gis/grass70
test -d OBJ.x86_64-unknown-linux-gnu || mkdir -p OBJ.x86_64-unknown-linux-gnu
gcc  -g -Wall -Werror-implicit-function-declaration -fno-common -Wextra -Wunused   -I/home/bob/dev/gis/grass70/dist.x86_64-unknown-linux-gnu/include -I/home/bob/dev/gis/grass70/dist.x86_64-unknown-linux-gnu/include  -D_FILE_OFFSET_BITS=64  -DPACKAGE=\""grassmods"\"   -I/home/bob/dev/gis/grass70/dist.x86_64-unknown-linux-gnu/include -I/home/bob/dev/gis/grass70/dist.x86_64-unknown-linux-gnu/include -o OBJ.x86_64-unknown-linux-gnu/geom.o -c geom.c
geom.c: In function ‘ternary_rotate’:
geom.c:21:5: warning: unused variable ‘res’ [-Wunused-variable]
geom.c: In function ‘radial2cartesian’:
geom.c:188:21: warning: ordered comparison of pointer with integer zero [-Wextra]
geom.c: In function ‘extends’:
geom.c:198:37: warning: unused parameter ‘pattern_size’ [-Wunused-parameter]
geom.c: At top level:
geom.c:2:15: warning: ‘dirs’ defined but not used [-Wunused-variable]
gcc  -g -Wall -Werror-implicit-function-declaration -fno-common -Wextra -Wunused   -I/home/bob/dev/gis/grass70/dist.x86_64-unknown-linux-gnu/include -I/home/bob/dev/gis/grass70/dist.x86_64-unknown-linux-gnu/include  -D_FILE_OFFSET_BITS=64  -DPACKAGE=\""grassmods"\"   -I/home/bob/dev/gis/grass70/dist.x86_64-unknown-linux-gnu/include -I/home/bob/dev/gis/grass70/dist.x86_64-unknown-linux-gnu/include -o OBJ.x86_64-unknown-linux-gnu/main.o -c main.c
main.c: In function ‘main’:
main.c:177:2: warning: format not a string literal and no format arguments [-Wformat-security]
main.c:198:2: warning: format not a string literal and no format arguments [-Wformat-security]
main.c:207:2: warning: format not a string literal and no format arguments [-Wformat-security]
main.c:213:2: warning: format not a string literal and no format arguments [-Wformat-security]
main.c:220:3: warning: format not a string literal and no format arguments [-Wformat-security]
main.c:234:3: warning: format not a string literal and no format arguments [-Wformat-security]
main.c:310:8: warning: format not a string literal and no format arguments [-Wformat-security]
main.c:366:5: error: implicit declaration of function ‘radial2cartesian’ [-Werror=implicit-function-declaration]
main.c:401:2: error: implicit declaration of function ‘write_contrast_colors’ [-Werror=implicit-function-declaration]
main.c:268:20: warning: unused variable ‘formC’ [-Wunused-variable]
main.c:268:13: warning: unused variable ‘formB’ [-Wunused-variable]
main.c:268:6: warning: unused variable ‘formA’ [-Wunused-variable]
main.c:76:22: warning: unused variable ‘radius’ [-Wunused-variable]
main.c:74:11: warning: unused variable ‘n’ [-Wunused-variable]
main.c:74:8: warning: unused variable ‘j’ [-Wunused-variable]
main.c:463:1: warning: control reaches end of non-void function [-Wreturn-type]
cc1: some warnings being treated as errors
make: *** [OBJ.x86_64-unknown-linux-gnu/main.o] Error 1
From: grass-user-bounces at lists.osgeo.org [mailto:grass-user-bounces at lists.osgeo.org] On Behalf Of Robert Andrew Brown
Sent: Tuesday, February 26, 2013 9:21 AM
To: grass-user at lists.osgeo.org
Cc: Phillip Owens
Subject: [GRASS-user] Geomorphons and extension manager
To whom it may concern,
I am trying to use extension manager in grass to install geomrphons. However, I am having trouble with the extension manager(error below). I emailed the geomorphon developer Jarek Jasiewicz(See Below) and he suggest I contact the GRASS-Users forum.
Please advise,
-Robert Brown
From: JASIEWICZ Jarosław <jarekj at amu.edu.pl<mailto:jarekj at amu.edu.pl>>
Subject: Re: Geomorphons
Date: February 26, 2013 11:56:20 AM EST
To: brown782 at purdue.edu<mailto:brown782 at purdue.edu>
On 02/26/2013 05:21 PM, brown782 at purdue.edu<mailto:brown782 at purdue.edu> wrote:
Dear Sir,
I use grass on my Mac OS X 10.8.2. I have been trying to compile grass to install the add-on Geomorphons. However, it is overwhelming to compile grass from source code as I have very little experience compiling programs. When I saw that your Geomorphons algorithm was part of the grass 7.0 add-ons I was pleased and tried to use the extension manager to add it to my grass add-on repository, however, I get an several errors which I have posted below. Any Suggestions?
g.extension extension=r.geomorphon/ operation=add
Fetching <r.geomorphon/> from GRASS-Addons SVN (be patient)...
Compiling...
In file included from geom.c:1:
local_proto.h:1:20: error: stdlib.h: No such file or
directory
local_proto.h:2:20: error: string.h: No such file or
directory
local_proto.h:3:18: error: math.h: No such file or directory
local_proto.h:4:27: error: grass/glocale.h: No such file or
directory
local_proto.h:5:23: error: grass/gis.h: No such file or
directory
local_proto.h:6:26: error: grass/raster.h: No such file or
directory
local_proto.h:56: error: expected specifier-qualifier-list
before 'RASTER_MAP_TYPE'
local_proto.h:66: error: expected specifier-qualifier-list
local_proto.h:74: error: expected specifier-qualifier-list
before 'CELL'
local_proto.h:139: error: expected declaration specifiers or
'...' before 'RASTER_MAP_TYPE'
local_proto.h:140: error: expected ')' before '*' token
geom.c: In function 'exposition':
geom.c:146: warning: incompatible implicit declaration of
built-in function 'fabs'
geom.c: In function 'extends':
geom.c:206: warning: incompatible implicit declaration of
geom.c: In function 'shape':
geom.c:232: warning: incompatible implicit declaration of
built-in function 'atan'
geom.c:236: warning: incompatible implicit declaration of
built-in function 'sin'
geom.c:237: warning: incompatible implicit declaration of
built-in function 'cos'
directory
directory
directory
directory
directory
before 'CELL'
lipo: can't figure out the architecture type of: /var/folder
s/wc/2dv9njw93k3bfyy5ppkw022h0000gn/T//ccESKY4a.out
make: *** [OBJ.x86_64-apple-darwin12.2.0/geom.o] Error 1
ERROR: Compilation failed, sorry. Please check above error messages.
(Tue Feb 26 09:40:18 2013) Command finished (3 sec)
Your help is much appreciated!
Sincerely,
Robert Brown
All messages comes from compiler informing you haven't installed standard librarires. This is however the issue of g.extension, which do not work well with Apple systems. Please contact grass dev team how to resolve this issue
regards
Jarek
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20130226/5c85c7a6/attachment-0001.html>
