[GRASS-user] Downscaling and aggregating raster categories/classes
Nikos Alexandris
nik at nikosalexandris.net
Wed Feb 27 09:51:01 PST 2013
Hi list.
I am trying to perform the following:
A classified map "A" of 25m pix res. has two main categories B and C.
Downscaling the map to 50m (map "B") results in pixels which correspond to 4
* 25m (original pixels).
Given the region extent is aligned, three possibilities may occur (near the
borders between categories B=11 and C=22) in terms of abundance/coverage in
the resampled map:
1. B = C <-- Mixed (M)
____
|B|B|
|C|C|
2. B > C
|B|B|
|C|B|
3. B < C
|B|C|
|C|C|
The new "categorisation" scheme can be expressed as (in r.mapcalc -- pseudo-
code)
1) if( count(B) > count(C), B)
2) if( count(C) > count(B), C)
3) if( count(B) = count(C), M )
The r.resamp.stats module seems to fit most aggregation tasks. In this
particular case it could be the method=mode. But,
1) the output is a DCELL map! I can understand why it is deriving floating
point values. Is a simple r.mapcalc round() operation enough to get close to
the desired values? Would an "-i" switch (as in integer) make sense here?
2) What happens when "method=mode" and "count(B) == count(C)", as described
above?
I know that something else can do it -- e.g. something like summing-up and
recoding later. That is however more steps. Even, method=sum also outputs
DCELL map(s).
Any recommendations? Can't this be done i a single step in grass (2 by 2
window)?
I've been reading the old and very good tutorial on r.mapcalc (thank you
Markus for pointing to it). Is it a better solution to construct this in
r.mapcalc using the map[r,c] operator?
Two essential questions:
- how to get a 2 by 2 *moving* window in r.mapcalc?
- how to replicate a "count()" method in r.mapcalc?
Thanks, Nikos
Desc: This is a digitally signed message part.
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20130227/944d454e/attachment.pgp>
