[GRASS-user] Geomorphons and extension manager
Robert Andrew Brown
brown782 at purdue.edu
Wed Feb 27 13:49:24 PST 2013
Sorry to be a pain,
So I have deleted the binary and tried to compile grass from source code. I am getting an error which is the same error that I have been getting after several hundred hours of tying to compile grass which is why I stopped trying to compile it. I installed Cairo through the GRASS http://www.kyngchaos.com/software:frameworks. The error is…
Unable to locate cairo_create
The ./configure script I am using is..
--with-cairo --with-cairo-includes="/Library/Frameworks/cairo.framework/unix/include/cairo /Library/Frameworks/cairo.framework/unix/include" --with-cairo-libs=/Library/Frameworks/cairo.framework/unix/lib --with-cairo-ldflags="-lcairo"
I have seen this error issue as far back as 2011.
Does anyone have any suggestions to a fix around?
Thanks,
-robert brown
On Feb 27, 2013, at 10:02 AM, Martin Landa <landa.martin at gmail.com> wrote:
> Hi,
> some compilation errors should be fixed in r55243.
> local_proto.h:1:20: error: stdlib.h: No such file or
> directo
> seems like standard header are missing on your computer. Try to install them, eg. on Debian/Ubuntu
> sudo apt-get install libc6-dev
> Martin
> Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20130227/17d623d5/attachment.html>
