[GRASS-user] movement direction surface in r.drain
Margherita Di Leo
diregola at gmail.com
Tue Jan 8 06:41:44 PST 2013
Thanks for super quick answer,
On Tue, Jan 8, 2013 at 3:25 PM, Markus Metz
<markus.metz.giswork at gmail.com>wrote:
> Check if the friction map is not all zero or NULL for the second
> polygon,
the friction map within the ending polygon has everywhere value 1.
> that the DEM covers the second polygon,
it does.
that the second
> polygon was not used in any way as input for r.walk,
sure.
> that the second
> polygon is actually reachable from the first polygon in the output of
> r.walk,
Not sure how to verify that, but i digitized a random point within the
ending polygon (i placed it somewhere in the center) and i used it as
starting point for r.drain, and obtained a nice least cost path line.
and that the current region covers the second polygon.
It does.
> Also
> have a look at the direction output of r.walk.
Looks OK (it has values) but i'm still not sure what should i check in it.
Thanks,
madi
> HTH,
> Markus M
> > Thanks in advance.
> > Best,
> > madi
> > Margherita DI LEO
> > Postdoctoral Researcher
> > European Commission - DG JRC
> > Institute for Environment and Sustainability (IES). Unit H03 – FRC
> > Via Fermi, 2749
> > I-21027 Ispra (VA) - Italy - TP 261
> > Tel. +39 0332 78 3600
> > margherita.di-leo at jrc.ec.europa.eu
> > Disclaimer: The views expressed are purely those of the writer and may
> not
> > in any circumstance be regarded as stating an official position of the
> > European Commission.
Margherita DI LEO
Via Fermi, 2749
Disclaimer: The views expressed are purely those of the writer and may not
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20130108/580745c4/attachment-0001.html>
