[GRASS-user] Create outer line of raster
Stefan Sylla
stefansylla at gmx.de
Tue Jan 8 17:56:32 PST 2013
Hi Paul,
you could also use the original ECW-file as a mask in GRASS:
g.copy ecw_sample,MASK
and then any action you will perform for raster processing will only be
within that Mask (assuming the ECW-file does not have any NULL-values
inside).
Stefan
2013/1/9 Paul Meems [via OSGeo.org] <ml-node+s1560n5026252h60 at n6.nabble.com>
> Hi List,
> I have an ECW-file which I convert to GeoTiff using gdal_translate.
> This GTiff file I use in GeoServer as a base map.
> This is working great, but because I compress the GTiff with JPEG I get
> white borders around my area. To solve this I can clip my GTiff with the
> outer line of my original ECW file.
> My question is how to create such an outer line. I can of course draw it
> myself using QGis or MapWindow but I'd prefer to let it calculated.
> Can GRASS do this? If so which command do I need.
> Thanks,
> Paul
> grass-user mailing list
> [hidden email] <http://user/SendEmail.jtp?type=node&node=5026252&i=0>
> http://lists.osgeo.org/mailman/listinfo/grass-user
> If you reply to this email, your message will be added to the discussion
> below:
> http://osgeo-org.1560.n6.nabble.com/Create-outer-line-of-raster-tp5026252.html
> To unsubscribe from Grass - Users, click here<http://osgeo-org.1560.n6.nabble.com/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=3884509&code=c3RlZmFuc3lsbGFAZ214LmRlfDM4ODQ1MDl8LTExNTE4ODczMTc=>
> NAML<http://osgeo-org.1560.n6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>
View this message in context: http://osgeo-org.1560.n6.nabble.com/Create-outer-line-of-raster-tp5026252p5026294.html
Sent from the Grass - Users mailing list archive at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20130108/7d745aa2/attachment.html>
