[GRASS-user] to move or not move ? grass64 <- ? -> 7.0
Maris Nartiss maris.gis at gmail.com
Fri Jan 11 01:42:18 PST 2013
Hello,
as a (not so active) GRASS developer, I also use 7 for almost all my
daily needs. I agree about all nice things of using 7 previously
stated, still I also must give a fat warning - some code in 7 is not
yet tested enough. There are new bugs present in 7 only too.
Here is (infamous) example of it - output result is shifted by n
cells.[1] Issue was present only in 7 in not so well tested new code.
Bugs do happen and GRASS 7 contains new bugs yet unknown. Anyone is
welcome to use GRASS 7, but remember to check outputs and be ready to
report back issues.
Maris.
1. https://trac.osgeo.org/grass/changeset/53889
2013/1/10 Markus Metz <markus.metz.giswork at gmail.com>:
> On Thu, Jan 10, 2013 at 8:33 PM, Patrice Dumas <pertusus at free.fr> wrote:
>> On Thu, Jan 10, 2013 at 03:59:49PM -0200, Milton Cezar Ribeiro wrote:
>>> Thanks Rashad,
>>> I understand that grass 7 have a lot of new features (or
>>> improved/fixed ones), including the powerful contribution of python.
>>> But I would like to hear from grass7 users about how stable are this
>>> version. Anyone survive using only  grass7 our we need to switch
>>> between them?
>> I have seen quite a bit of bugs in grass 7, but the GRASS developpers
>> are very quick to fix a correctly reported bug.
> Some of the bugs reported by you were really helpful to improve new
> functionality in GRASS 7. GRASS developers actually depend on this
> kind of feedback, and the more power-users use GRASS 7 and report any
> bugs, the better. In general, I estimate that GRASS 7 (on the command
> line) is as robust, but if in doubt faster and less resource intensive
> than GRASS 6.
> Some of the bugs reported by you apply to GRASS 6 only, are fixed in
> GRASS 7 and can not be backported to GRASS 6 because the required
> changes would break GRASS 6 compatibility.
> Other bugs that were present in GRASS 6 + 7 are only fixed in GRASS 7
> and may or may not be backported to GRASS 6.
> Obviously I am advocating the use of GRASS 7, but for production work
> I would, like Paolo, recommend to have GRASS 6 on the side.
> As a GRASS developer, I personally use only GRASS 7 for production work.
> Markus M
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
