[GRASS-user] Single grass window as attached display
    SWAPAN GHOSH
    swap.ghsh at gmail.com
    Fri Jan 11 04:21:27 PST 2013
Please see the error when start bhoomi(Grass).
[image: Inline image 1]
Thanks & Regards,
Swapan
On Fri, Jan 11, 2013 at 5:43 PM, Rashad M <mohammedrashadkm at gmail.com>wrote:
> what error you are getting?
> On Fri, Jan 11, 2013 at 4:44 PM, SWAPAN GHOSH <swap.ghsh at gmail.com> wrote:
>> *Dear Rashad,*
>> * *As per your attachment I have change the entire program. But then
>> grass will not start.
>>  Please give me a out line how to deploy this program change.
>> *Thanks & Regards,*
>> *Swapan*
>> On Wed, Jan 9, 2013 at 5:59 PM, Rashad M <mohammedrashadkm at gmail.com>wrote:
>>> try this attachment
>>> On Wed, Jan 9, 2013 at 5:37 PM, SWAPAN GHOSH <swap.ghsh at gmail.com>wrote:
>>>> *Dear Rashad,*
>>>> Can you please send me the wxPython folder by making it as wxPython.rar
>>>> and any other related doc from your local copy.
>>>> This lay out is my exact requirement. And which version of python you
>>>> used.
>>>> I am waiting for kind help.
>>>> *Thanks & Regards,*
>>>> *Swapan*
>>>> On Tue, Jan 8, 2013 at 4:31 PM, Rashad M <mohammedrashadkm at gmail.com>wrote:
>>>>> you may give a look at DataCatalog[1]. code is very old. I have some
>>>>> changes in my local copy. But didnt get time to push to addons. The idea is
>>>>> pretty much same and it can also communicate with ossim using planetSasha.
>>>>> Unfortunately work is incomplete :(
>>>>> [1]
>>>>> http://svn.osgeo.org/grass/grass-addons/grass6/gui/wxpython/wx.data_catalog/
>>>>> [2]
>>>>> http://www.geofemengineering.it/GeofemEngineering/Blog/Voci/2009/12/13_Planet_-_Sasha.html
>>>>> On Tue, Jan 8, 2013 at 4:23 PM, SWAPAN GHOSH <swap.ghsh at gmail.com>wrote:
>>>>>> *Dear Vaclav,*
>>>>>> Thank you very much for your good advice. I am trying to make it as
>>>>>> single window.
>>>>>> I have already see the link you send and found it suitable.
>>>>>> Actually, I am not Python developer. I am basically c\c++ developer
>>>>>> for console application. Here GUI is built by wxPython. So I have to learn
>>>>>> the wxPython.
>>>>>> Once, the problem is solved surely I share it with you and the
>>>>>> grass-user list.
>>>>>> *Thanks & Regards*
>>>>>> *Swapan*
>>>>>> On Tue, Jan 8, 2013 at 1:55 PM, Vaclav Petras <wenzeslaus at gmail.com>wrote:
>>>>>>> Hi,
>>>>>>> this is more dev than user question since a lot of programming is
>>>>>>> needed. There are some wxGUI code refactoring efforts (code is
>>>>>>> published in grass 7, description will be published). One of long
>>>>>>> term
>>>>>>> goals of refactoring is to enable creation of one big window with
>>>>>>> lmgr
>>>>>>> and display. However, this refactoring is not finished and currently
>>>>>>> it is very hard to reuse wxGUI components/classes to build another
>>>>>>> GUI.
>>>>>>> I thing you have two possibilities:
>>>>>>> 1) Try to connect lmgr and display anyway. Maybe, it is possible to
>>>>>>> make it work for some task but the whole thing would be probably very
>>>>>>> buggy.
>>>>>>> 2) Build a new GUI from components/classes which are already prepared
>>>>>>> for reuse. There is a wxIClass (iclass, g.gui.iclass) module which
>>>>>>> reuses mapwindow (widget where a map i placed) and adds some very
>>>>>>> simple layer management (however, simple layer manager class is still
>>>>>>> missing). Depends on what you want, but maybe this is the way you
>>>>>>> want
>>>>>>> to go.
>>>>>>> Since this is a problem which is interesting for more people [1,2],
>>>>>>> please share your ideas and advances.
>>>>>>> Vaclav
>>>>>>> [1] http://grasswiki.osgeo.org/wiki/WxGUI#Layout
>>>>>>> [2] http://grasswiki.osgeo.org/wiki/GRASS_SoC_Ideas_2009#wxGUI
>>>>>>> On 8 January 2013 08:35, SWAPAN GHOSH <swap.ghsh at gmail.com> wrote:
>>>>>>> > Dear all,
>>>>>>> > Any body can help me for technical solution to change the current
>>>>>>> window for
>>>>>>> > grass gis 6.5 to attached display as layer manager and display
>>>>>>> window in a
>>>>>>> > single window.
>>>>>>> > Actually I  want to change this detached window for my own perpose.
>>>>>>> > Thank & Regards,
>>>>>>> > Swapan Ghosh
>>>>>>> > _______________________________________________
>>>>>>> > grass-user mailing list
>>>>>>> > grass-user at lists.osgeo.org
>>>>>>> > http://lists.osgeo.org/mailman/listinfo/grass-user
>>>>> Regards,
>>>>>    Rashad
>>> Regards,
>>>    Rashad
> Regards,
>    Rashad
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20130111/63a80fa0/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20130111/63a80fa0/attachment-0001.png>
