[GRASS-user] Differences Between ERDAS and GRASS About NDVI Statistics
Nikos Alexandris nik at nikosalexandris.net
Mon Jan 14 00:09:00 PST 2013
Güner:
Hi Güner!
> @Nikos: I'll send information about maps tonight. I'll send 'r.describe -r'
> output also.
I think it might not be necessary. As Sylvain pointed-out, and I confirm this
(had a quick look in the morning), the reported layere dimensions are
different!  Check it out please.
This might be the single root of evil in this case.
> @Sylvain: Thank you, I didn't noticed the differences, my friend might had
> done histogram strecthing over results, so this may be the reason for -2/2
> thing, I will check this.
> By the way I'm not sure how we can make data to have same layer extent and
> dimension in both programs. I didn't do a special thing before calculation,
> I just used g.region and r.mapcalc methods.
How exactly? After importing you need to
g.region rast=ImportedRasterMap
or similar.
[rest deleted]
Best, Nikos
