[GRASS-user] r.hazard.flood.py Grass 6.4.3RC1
Margherita Di Leo
diregola at gmail.com
Wed Jan 16 04:53:01 PST 2013
On Wed, Jan 16, 2013 at 1:10 PM, Paul Shapley <p.shapley at gmail.com> wrote:
> Hi,
> I'm using the GUI 'File > Launch Script' then opening it from the
> 'scripts' directory
> C:\Program Files\GRASS GIS 6.4.3RC1\scripts
Could you try to run it from command line, just to be sure if the error is
in the GUI or in the script itself.
Thanks.
madi
> *I'm using WinXP at the moment but will need to use the script with
> Ubuntu 12.10 later.*
> Many thanks,
> Paul Shapley
> On 16 January 2013 08:40, Margherita Di Leo <diregola at gmail.com> wrote:
>> Hi Paul,
>> Could you indicate the exact command line that you are executing?
>> Also, on which OS?
>> Thanks,
>> Madi
>> On Wed, Jan 16, 2013 at 9:18 AM, Paul Shapley <p.shapley at gmail.com>wrote:
>>> Hi All,
>>> I'm getting the following error trying to execute the r.hazard.flood
>>> python script. The module will load and accept the parameters but does not
>>> seem to execute.
>>> Any advice appreciated.
>>> Thanks,
>>> Paul Shapley
>>> **kwargs)
>>> wx._core
>>> PyAssertionError
>>> C++ assertion "m_pendingEvents" failed at
>>> ..\..\src\common\event.cpp(1172) in
>>> wxEvtHandler::ProcessPendingEvents(): Please call
>>> wxApp::ProcessPendingEvents() instead
>>> Traceback (most recent call last):
>>> File "C:\Program Files\GRASS GIS
>>> 6.4.3RC1\etc\wxpython\gui_core\goutput.py", line 980, in
>>> OnProcessPendingOutputWindowEvents
>>> self.ProcessPendingEvents()
>>> File "C:\Program Files\GRASS GIS 6.4.3RC1\Python27\lib
>>> \site-packages\wx-2.8-msw-unicode\wx\_core.py", line 3871,
>>> in ProcessPendingEvents
>>> return _core_.EvtHandler_ProcessPendingEvents(*args,
>>> **kwargs)
>>> wx._core
>>> PyAssertionError
>>> Paul J. Shapley
>>> grass-user mailing list
>>> grass-user at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/grass-user
>> Margherita DI LEO
>> Postdoctoral Researcher
>> European Commission - DG JRC
>> Institute for Environment and Sustainability (IES). Unit H03 – FRC
>> Via Fermi, 2749
>> I-21027 Ispra (VA) - Italy - TP 261
>> Tel. +39 0332 78 3600
>> margherita.di-leo at jrc.ec.europa.eu
>> Disclaimer: The views expressed are purely those of the writer and may
>> not in any circumstance be regarded as stating an official position of the
>> European Commission.
> Paul J. Shapley
Margherita DI LEO
Via Fermi, 2749
Disclaimer: The views expressed are purely those of the writer and may not
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20130116/a8360ea4/attachment.html>
