[GRASS-user] r.hazard.flood.py - GRASS 6.4.3RC2 WinXP
    Margherita Di Leo
    diregola at gmail.com
    Thu Jan 17 05:00:30 PST 2013
On Thu, Jan 17, 2013 at 1:37 PM, Paul Shapley <p.shapley at gmail.com> wrote:
> Hi,
> This flood module is working in the latest stable release, however there
> is an issue in that it does not produce the flood 'test1' map only 'test2'
> (the MTI map). Running the module seems to generate three maps 'r.clump',
> 'r.flood' and 'test2'. Just need confirmation that this is how it is meant
> to be and is the error below normal or does the module require fine tuning.
you need to install r.area (addon).
> Also is there any detailed information on this module? Where can i find
> it?.
This addon is based on an experimental procedure to detect flood prone area
on the basis of DEM derivatives. A couple of papers have been produced
about, [1] describes the development of the theory behind and [2] the
implementation.
*[1] Manfreda S., Di Leo M., Sole A., Detection of Flood Prone Areas using
Digital Elevation Models, Journal of Hydrologic Engineering,
(10.1061/(ASCE)HE.1943-5584.0000367), 2011.*
*[2] Di Leo M., Manfreda S., Fiorentino M., An automated procedure for the
detection of flood prone areas: r.hazard.flood, Geomatics Workbooks n.10,
2011. (PDF<http://geomatica.como.polimi.it/workbooks/n10/GW10-FOSS4Git_2011.pdf>
This latter is free access, if you need the former and don't have access,
let me know and I'll send you the author's copy.
Regards,
madi
Margherita DI LEO
Postdoctoral Researcher
European Commission - DG JRC
Institute for Environment and Sustainability (IES). Unit H03 – FRC
Via Fermi, 2749
I-21027 Ispra (VA) - Italy - TP 261
Tel. +39 0332 78 3600
margherita.di-leo at jrc.ec.europa.eu
Disclaimer: The views expressed are purely those of the writer and may not
in any circumstance be regarded as stating an official position of the
European Commission.
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20130117/6e143b6a/attachment.html>
