[GRASS-user] looking for a solution to a v.net error
דור פרידמן
dof1985 at gmail.com
Sun Jan 20 04:33:23 PST 2013
Hi all,
I was using v.net (operation=connect) to create a network for a
v.net.distance analysis. I'm using GRASS 6.4.2 using QGIS 1.8 plugin.
My attempt to connect a polyline map with about 11000 categories to a
points map with 25 has failed due to an error which described below.
- My code was:
v.net input=network points=cdw1c output=network_v2 operation=connect
> threshold=4500
- My threshold is the maximum distance between a point category to the
polyline map and was calculated by v.distance. I've also tried a smaller
float to test it, namely threshold=100
- The error was:
- Windows alert claiming that v.net.exe has stopped working
correctly... and the program was terminated.
- Additionally, I have received the following output in grass shell
Assertion failed: !p->taken[i], file split_q.e, line 69
An image using Prt Scr is attached.
Can someone help me to figure out what am I doing wrong?
Thanks in advanced,
Dor
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20130120/8825646f/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20130120/8825646f/attachment-0001.png>
