[GRASS-user] r.geomorphon add-on installation error on Arch-Linux
Paulo van Breugel
p.vanbreugel at gmail.com
Wed Jan 23 11:39:09 PST 2013
Hi, no solution unfortunately, but just to confirm that I get the same
error at install on Ubuntu 12.10.
Paulo
On Wed 23 Jan 2013 01:30:31 PM CET, Haziq Noor Ariff wrote:
> Hi,
> I'm trying to install 'r.geomorphon' add-on module from
> http://sil.uc.edu/downloads.html on my recently-built Arch Linux
> system with GRASS7-svn. I've used this module on my old Ubuntu system
> a-lot, but somehow I can't get it to install on Arch..
> I did:
> $ make MODULE_TOPDIR=/usr/local/grass-7.0.svn
> $ sudo make MODULE_TOPDIR=/usr/local/grass-7.0.svn install
> The 'make' command gives no error. The 'make-install' command gives an
> error that says:
> /usr/bin/install -c /usr/local/grass-7.0.svn/bin/r.geomorphon
> /usr/bin/install: ‘/usr/local/grass-7.0.svn/bin/r.geomorphon’ and
> ‘/usr/local/grass-7.0.svn/bin/r.geomorphon’ are the same file
> make: *** [install] Error 1
> What should I do? I didn't get this error in Ubuntu... Would
> appreciate any help, thanks!
> In dire need,
> Haziq Noor Ariff.
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
