[GRASS-user] Loss of data using v.net
    Moritz Lennert
    mlennert at club.worldonline.be
    Thu Jan 24 00:34:48 PST 2013
[please keep discussions on the mailing list]
On 23/01/13 22:23, דור פרידמן wrote:
> I forgot to mention that I am using GRASS 6.4.2
These is an issue with some of the v.net.* modules (incl v.net.distance)
in 6.4.2: you cannot correctly input arcs in layer 1 and nodes in layer
2. You, therefore, have to use layer 1 for everything, making sure that
category values of arcs and nodes do not overlap.
I would really recommend that for serious network analysis you use
grass7 in which Markus Metz has not only made the interfaces of the
modules more consistent, but also increased their efficiency.
Moritz
> 2013/1/23 Moritz Lennert <mlennert at club.worldonline.be
> <mailto:mlennert at club.worldonline.be>>
>     On 23/01/13 20:22, דור פרידמן wrote:
>         I'm trying to build a network in GRASS in order to find the shortest
>         path from any settlement out of 1120 (points), to one waste
>         treatment
>         facility out of 27 (points). I plan to use v.net.distance which is
>         designated to this purpose, and to define source and destination
>         points
>         using a column called "type". In that column I have assigned the
>         settlements layer with the number 5 and the treatment facilities
>         with 1.
>         My problem occurs when I try to create the network using v.net
>         <http://v.net>
>         <http://v.net>; If I define nodes layer (nlayer=2) to be 2, I
>         lose all
>         the points and can't find it, even by using v.extract.
>     What is the exact comman line for v.extract that you used ? Did you
>     set layer=2 ?
>     What does v.category option=report give you on the file resulting
>     from v.net <http://v.net> ?
>     Which version of GRASS are you using ?
>         Otherwise (when
>         nlayer=1) the attributes describing type are being auromatically
>         changed
>         to 4, which is the type attribute for roads.
>     v.net <http://v.net> certainly should not (and AFAIK does not)
>     change attribute data. Actually attribute data of points connected
>     to the network with v.net <http://v.net> operation=connect is not
>     kept. As mentioned in the man page you have to reconnect your points
>     to the attribute data by hand after running v.net <http://v.net>.
>         Any one has an idea why I'm losing this crucial data and how can I
>         prevent it from happening?
>     It would help if you could give a reproducible case description,
>     including data (possibly from the NC demo dataset), so that we can
>     see exactly what is going wrong where.
>     Moritz
