[GRASS-user] error: accumulation map does not match with elevation map! (r.basin)
Markus Metz markus.metz.giswork at gmail.com
Sat Jan 26 01:54:41 PST 2013
On Fri, Jan 25, 2013 at 11:53 AM, Giuliano Urgeghe <giuliano.u at gmail.com> wrote:
> Thank you Markus,
> would you suggest following Ubuntu's compilation instructions with OS Mint
> 14 or OS KUbuntu?
Since Mint is based on Ubuntu, the compile instructions for Ubuntu [0]
should work. Please let us know if they work or need modification.
[0] http://grasswiki.osgeo.org/wiki/Compile_and_Install#Ubuntu
> View this message in context: http://osgeo-org.1560.n6.nabble.com/error-accumulation-map-does-not-match-with-elevation-map-tp5029128p5029834.html
> Sent from the Grass - Users mailing list archive at Nabble.com.
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
